20 Most Recent
Leviton R03-5634-A Two Single-pole Switches Questions & Answers
Im installing a two way switch and have one hot
If I understand you correctly, your hot lead should attach to 1 switch and a common wire goes from that switch to the other switch. Here's a link to a good explanation of 2 way switch wiring. Essentially you run power to one switch, and that same switch sends power via 1 of 2 other wires to the second switch. The light (or other device) is then connected to the second switch. Hopefully the diagrams in the following link will help you. In any case you need 3 wires at each switch. Good luck!
http://2wayswitch.com/2-way-switch-wiring-diagram/
5/29/2019 10:50:00 AM •
Leviton...
Answered
on May 29, 2019
How can i i install the sockets in the wall?
Normally there is a box in the wall with the wires contained therein. I would then connect the wires to the appropriate screws and then align the screws on the socket to the box that is in the wall and tighten them. Then I would put on a cover plate and call it finished.
If the box is not in the wall then go to a big box store and get a rework box, the sales people will be glad to help you.
4/30/2014 12:00:14 AM •
Leviton...
Answered
on Apr 30, 2014
I cannot turn off light that uses a Leviton Cat /no 16400, DHC switch not can i find the receiver box that controls the lights
A Leviton DHC receiver device can look like any other switch or receptacle so if you didn't install it or not provided a map then you'll need to locate it.
Likely the wall switch that originally controlled the light was replaced with DHC device and paired with the 16400 at another location. If you can't identify it, then removing face plates and devices may be the only practical method to locate it.
If your not comfortable with removing devices safely, hire an electrician.
https://www.mc-mc.com/ASSETS/DOCUMENTS/ITEMS/EN/Decora_6375_Catalog.pdf
7/5/2021 2:59:40 PM •
Leviton...
Answered
on Jul 05, 2021
Wiring a leviton 5641 so fan & light turn on separate with red & black wires
the 5641 is a dual switch for three way and single pole. If you want the switches to operate the CF. Connect the power to one of the two screws on the right side as you face the switch. then connect one wire to the screw on the bottom left side. connect the other screw to one of the two screws on the top left. This assumes the Red and Black you mentioned are the switch legs going to the CF.
5/1/2017 3:42:09 AM •
Leviton...
Answered
on May 01, 2017
Wire occupancy sensor to control receptacle
Your description doesn't explain the circuit, the function of the wires or how the switch controls the outlet and whether the switch is a single pole or two-pole switch. Without such details it is difficult to visualise the circuit.
I advise before you go further to test the sensor in a known good and correctly wired outlet using a length of cable and a suitable plug for the outlet. It is possible the unit is faulty. If it functions correctly on test you will need to understand the circuit and the function of the wires before you rewire it to assure success.
4/18/2016 2:23:52 AM •
Leviton...
Answered
on Apr 18, 2016
