20 Most Recent Weiser Lock POWERBOLT ELEC DEADBOLT Questions & Answers
Change the battery. Entering the code is draining the power and then not enough to unlock.
Weiser Lock... | Answered on Apr 08, 2019
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Weiser Lock... | Answered on Nov 13, 2018
You can change codes as often as you like, for use by babysitters, contractors, etc. You can also reset the lock so you can reset the master code, which is needed in order to set the other user codes.
Rather than re-type all the step-by-step instructions, since you also could benefit by having a copy of the manual for your use and reference, I'll give you a link to a free copy you can save and print.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful and best regards!
Weiser Lock... | Answered on May 11, 2018
i have the same problem in northern canada... did you find a fix yet
Weiser Lock... | Answered on Oct 12, 2017
You should replace your batteries as the motor that moved the deadbolt does not have enough power to move it with weak batteries. If that fails make sure the deadbolt moves freely when the lock is removed as the mis-aligned mounting will cause excessive force be exerted to move the deadbolt. See http://www.weiserlock.com/Support/Faq/50160000000HhbGAAS.aspx
Weiser Lock... | Answered on Feb 15, 2016
Pull the inside cover away from the door, to remove. This exposes the battery holder. Replace all four AA batteries with new alkaline AAs The cover snaps on. Align top first.
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
Weiser Lock... | Answered on May 24, 2014
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
149 questions posted
Top Weiser Lock Locks & Locksmithing Experts
Scoee Scoffer
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Weiser Lock Locks & Locksmithing
Most Popular Question
need change code
  • Locks & Locksmithing
