20 Most Recent
Dewalt Versa Clutch Tek Screw Gun DW268 Questions & Answers
What's wrong with my screw gun when the bit keeps
The bit holder resides in the clutch housing which has a collar with a ball bearing that the notch in the bit holder snaps into. It would seem that the ball bearing has slipped out of the cooler on the clutch housing, therefore nothing is locking it into placed. If you need a diagram, let me know.
How do I replace the driver bit shaft?
I suggest you should go into that supply store and ask for help, if they are decent, they will surely try to help you, they surely have some experience with that.
No power dw268 tech gun
I would take this back for warranty repair, Dewalt has a one year warranty on their tools. If that is not an option get back with me on the exact model and type number and I will look into it further
How do you change blades on DeWalt DW50 planer
https://www.weeklytools.com/different-uses-for-an-angle-grinder/
An angle grinder is a multifaced handheld power tools that was invented by a German company. We may don't know a lot about this tool because it is an unrecognized instrument like some other tools. Now we will discuss different Uses for angle grinder.
An angle grinder is also known as a side grinder or disc grinder. It is a machine with a rotating abrasive cutting disc. Angle grinders can be powered by an electric motor, petrol engine, or compressed air. It comes in a wide variety of different sizes and powerful motor, each with the other purpose. Once anyone knows about these, he can easily find out the best angle grinder for his needs. Angle grinders are quality fulled equipment for any metal fabrication shop, and those are typically used in auto repair, workshops, and construction sites.
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
