20 Most Recent Winco 100-Amp Automatic Transfer Switch - 4WATS100-31R Questions & Answers
Winco model # 110/60 ATS -3/B Will not run thru its 15min weekly cycle and will not automatically start when power goes out?????
Likely 3 position switch on front of ats. If it were just no exercise I would say clock.
3/16/2013 11:54:41 PM • Winco 100-Amp... • Answered on Mar 16, 2013
2answers
Winco TMT-DG4 what is replacement battery?
  • Battery is Replacable
  • #TMT-DG4 WINCO
4/24/2017 10:47:43 PM • Winco Electrical... • Answered on Apr 24, 2017
Coleman Powermate 6250/500 PM0545005 has power to just one side of the 120/240 outlet. the 120 volt outlets have none. Ran just fine onr week ago
The capacitor has no bearing as you have output on one leg. Take or have an electrician check the power from L1 to N and L2 to N right as it comes off the generator stator, before any breakers and receptacles. If you have no power still on one leg, the stator is bad. The rotor is fine as you indicate you have power on one leg, you may have lost one set of windings in sthe stator. Good Luck
2/28/2015 11:15:30 PM • Winco Electrical... • Answered on Feb 28, 2015
0answers
No ac output on a winco 9000 multi fuel home power
How long has the unit sat?After long periods the rotor loses it's residual magnetism and may have to be field flashed for a few seconds. Also check that the rotor slip rings are clean and shiney
11/17/2013 2:43:02 PM • Winco Electrical... • Answered on Nov 17, 2013
Lose of residual magnatism
I have not worked on this model, however other Wenco generators have a capacitor the retains a charge to aid in the beginning of the power cycle. Also diodes could be leaking. Simple check with meter but parts must be removed or isolated to properly test. Be sure to short leads of cap before testing. More information is available at WWW.wencogen.com.
12/5/2008 5:41:45 AM • Winco Electrical... • Answered on Dec 05, 2008
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Winco 100-Amp Automatic Transfer Switch - 4WATS100-31R Logo
1 questions posted
Top Winco Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a Winco Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Winco Electrical Supplies
Most Popular Question
winco model 110 60 ats 3 b will not
  • Electrical Supplies
