20 Most Recent
Makita 1806B 6 - 3/4'' Planer Questions & Answers
Carbon brush sparking and cause no power for electric motor
You have either one of 2 problems. Either you have a brush that is hung up and burnt or the armature is bad. If you are comfortable in removing the brushes first unplug the tool and remove the brush caps. Pull brushes out and look at the spring making sure not collapsed and then the end of brush that rides on armature for a burning look. Then I would look into brush tube and try and turn by hand the roller to look at the segments of armature best you can. If this needs anything other than brushes I would take it to a repair shop. Good luck
Dave
Carbon brush sparking on one side
try switching out the brushes first. Check for warrants spots on the armature.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Can i replace the casing of my makita planer
Yes but you'll spend close to $200 for a main frame (PN159984-0) or $50+ for a motor housing (PN156414-2). The chip cover (PN316966-7), handle set (PN181151-9) and belt cover (PN343301-6) are about $15 to $20 each.
Exesive sparking
Couple things, I would first take the handle half apart (if there one) and look at the condition of the commutator. Second make sure the brushes are fully seated. What happened to the old set of brushes, why did you replace them. Are the brushes you bought made for this tool? Sometimes when replacing the brushed the commutator has to seat them. THis is tricky unless you know what you are doing. Check on the items I suggested and get back to me and lets see what else we can look at. One more thought on the armature commutator how do the bars look, are they all pretty much the same or do you see some that are raised above others, if so the armature is bad and needs replaced.
My cricut explore air 2 will not load my mat, what could be the problem?
Cricut Explore Air 2 helps in cutting the beautifully intricate designs using the compatible cutting machines. However, in some situations, you can get the problem where you will not able to use the mat. In this situation, you first make sure you are following the right guide to load the mat, check if the mat is compatible with your Explore Air 2 machine, or your device is not facing any problem.
To get rid of this issue, you have to reset all of your devices and set up the machine once again. Also, check if the mat is not damaged, refer to the Cricut crafting guide for using the mat, use the compatible mat, and more. You can also connect to the Cricut customer support team to get more info from professionals to resolve the issue.
Constraints about making a Jaws of Life model with cardboard, split pins, syringes and plastic tubing.
Question edited for clarity, otherwise this question makes no sense. I presume you mean a MODEL of the Jaws of Life.
Large capacity syringe powering a small capacity syringe with give a significant pressure advantage. The only issue I can think of is the the friction of the secondary piston may be too sticky on the wall of the smaller syringe but if you fill the system with water, you will get true hydraulic results because air can be compressed but water can't
Crafting Clear and Effective Troubleshooting Guides: A Handy Guide for DIY...
Are you tired of scratching your head over malfunctioning gadgets or appliances? Fear not! With a well-crafted troubleshooting guide, you can conquer technical challenges like a pro. Here are some expert tips to help you write troubleshooting guides that shine:
- Know Your Audience: Understand who will be using your troubleshooting guide. Are they beginners, enthusiasts, or experts? Tailor your language and level of detail accordingly to ensure accessibility and effectiveness.
- Start with the Basics: Begin your guide with an overview of the problem and its potential causes. Break down complex issues into simple, easy-to-understand steps. Remember, clarity is key!
- Step-by-Step Solutions: Provide clear, concise instructions for each troubleshooting step. Use numbered lists or bullet points to outline the sequence of actions users should take. Include relevant images or diagrams to enhance understanding.
- Use Descriptive Language: Describe symptoms, error messages, and actions in detail. Avoid jargon or technical terms that might confuse readers. If necessary, define unfamiliar terms or provide a glossary for reference.
- Highlight Common Pitfalls: Anticipate common mistakes or misconceptions users might encounter. Address these pitfalls proactively to prevent frustration and ensure a smoother troubleshooting experience.
- Include Troubleshooting Tips: Offer troubleshooting tips or tricks to expedite problem-solving. Share insights or shortcuts that can help users navigate tricky situations with ease.
- Test and Revise: Put your troubleshooting guide to the test! Walk through the steps yourself to identify any ambiguities or gaps in instructions. Solicit feedback from users to refine and improve your guide over time.
- Update Regularly: Technology evolves rapidly, so it's essential to keep your troubleshooting guide up-to-date. Stay informed about new developments, software updates, or common issues reported by users. Update your guide accordingly to ensure its relevance and accuracy.
Remember, writing an effective troubleshooting guide is as much an art as it is a science. By following these tips and putting yourself in the shoes of your audience, you can create guides that empower users to tackle technical challenges with confidence. Happy troubleshooting!
I need 4 springs for under blades for a pro tech cs6007 contrator series planer
you can find replacement blades (also known as knives) made from a special V2 alloy (high-speed steel) on the MyWoodcutters website. Each set includes 3 HSS blades specifically designed for the CS 6007 model. The cost for a set of 3 blades is $61.50
to replace the springs for the under blades, I recommend checking with a local hardware store or contacting ProTech directly to inquire about availability..
For other parts or accessories, consider exploring online marketplaces like eBay.
