20 Most Recent Coleman 2 Burner Propane Stove 5430E700 Questions & Answers
If it won't light with a match,then the orifice is plugged.If it will light with a match because you can hear the gas coming out,then your striker on the knob is bad.It's replaceable.
Coleman 2 Burner... | Answered on Apr 14, 2014
Try the following:
Reinstall propane with fresh full propane canister. If problem persists then check tubing in stove for blockages. Make sure you open valve all the way for lighting.
If this doesn't work you may have a defective unit and need to replace it or send it for repair.
Thomas
Coleman 2 Burner... | Answered on Dec 03, 2013
Yes. There are multiple adapters made to fit this application. Your local walmart most likely will have them. http://www.walmart.com/ip/Coleman-5-High-Pressure-Propane-Hose-and-Adapter/19897422
Coleman 2 Burner... | Answered on Oct 17, 2013
Its a safety feature of the regulator. The regulator is designed with a pressure release valve. This has happened to me twice: once with a carbon dioxide tank for my kegerator and once on my propane stove. In both cases I left the regulator (designed with a max pressure rating of X psi) attached to a full bottle in the sun. The heat caused the pressure to exceed the limit of the regulator and the release valve popped. A welding supply store may be able to reset/replace the mechanism but in my case I just bought a new regulator for about $15.
Coleman 2 Burner... | Answered on Jun 17, 2012
Please don't try to use this stove without a regulator. It is extremely unsafe, and not worth it. If you can't find a regulator cheap online (I couldnt find one for less than $30) - just buy a new one. You can find a whole new cookstove on sale for $20-30 at most outdoor stores like Big 5, Dicks, Walmart...good luck!
Coleman 2 Burner... | Answered on Dec 10, 2010
hi,
1 GRATE
Assembly
2 Burner Assembly
3 REGULATOR
Assembly
4 VALVE WHEEL
5 IGNITER KNOB & SCREW
1)Blow air into the valve wheel connections so the blockages will be cleared.
2)Remove the burners and clean it perfectly.Dry the burners using hair dryer and remove the parts and clean everything perfectly.Burners will be screwed with two screws.
3)Knob switch could be also could be problem,small dust particles will block the flow of current to bypass switch.
4)In some Coleman 2 Burner Propane Stove models the Ignitors are prone to defective.They go bad when use for long time.Replace it if it is defective ignitors cost very less.Remove the screws to change the ignitor.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Coleman 2 Burner... | Answered on Sep 11, 2010
Coleman 2 Burner Propane Stove 5430E700 Logo
Popular Tags
35 questions posted
Top Coleman Sport & Outdoor - Others Experts
Vernon Taylor
john h
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Coleman Sport & Outdoor - Others
Most Popular Question
20lb tank hooked up coleman 2 burner
  • Sport & Outdoor - Others
