20 Most Recent
Wmh Tool Group Jet 13" Planer Molder Questions & Answers
How to make crown molding with a jet 13" planer /molder
You may want to go to the Forum at OWW (Old WoodWorkers.com). What your attempting to do requires several Passes. I usually Rough out BOTH Face & Bevel, then make 2 more cuts each, to get to the Finished dimensions. I usually start with a Face Cut 1st, leaving some Flats for Square then do the Bevel Cuts to Desired dimension, then back to the Face, & take it down to where the Finished product is where I want it.
Blade guard for Atlas 6'' jointer
I can send you pics of the one I made from plywood for this same jointer. If you're looking for an original I can't help you there.
Need a manual for a
If you're still interested, please see
this answer and follow the links.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Tuckpointing brick, mortar won't stay in. have a
is the recess deep enough on the bed and perp joints if so is the mortar the right consistency.
a little tip is to wet the joints with water before jointing. it stop the mortar drying out to quick
What is the proper way to hold the masonry trowel?
On the website http://www.masonryforlife.comthey explain: "Learning to hold the trowel correctly is important and will make the job easier. Gripping the handle with four fingers and putting the thumb on top of the metal band (ferrule) on the handle is how most masons hold a trowel."
1 yard cement is how many cubic feet
kakima is 100% correct, but to add to it so you understand how he got that 27 cubic feet... you can picture a cube.
A cubic yard is 3 foot tall x 3 foot wide x 3 foot high.
(A cubic foot is 1 foot tall x 1 foot wide x 1 foot high).
So 3 x 3 x 3 = 27.
Rewiring switch
I do not have a clue as to what you have but a simple switch has two connections and you can connect either way.
