20 Most Recent
Weller Mcm Magna Lite Butane Table To Questions & Answers
Weller tcp 1iron overheating
There is a bimetalic strip and a magnet that can get stuck in the closed position.
Tapping the iron on the end of the bit can release it otherwise a new element will be required.
I have a Weller 1002B soldering station. Haven't
Hi, I'm not sure the tip is defective. Check that the tip is screwed in tight. If it is not good and tight the tip will not get a good heat transfer from the solder wand. Hope this helps. If the wand will heat then the tip should.
Can u use the Weller universal soldering gun for making and repairing jewelry?
Unless you are only interested in soldering tin/lead joints... I sincerely believe that answer to be "No"...
What kind of metals were you planning on working with
would be a GREAT PLACE to start...
and the figure out the temperatures you will need to achieve..
A word of extreme CAUTION.
Working surfaces have to be able to withstand EXTREME TEMPERATURES.
Cement will come apart with explosive force... and getting any water onto molten metal can also have catastrophic consequences... so a little supervised experience would be well advised place to begin...
