20 Most Recent Makita HR2450F Rotary Hammer Questions & Answers
Use a fine jewellers screwdriver or thin stiff wire in the small holes next to the wire holes.
Makita HR2450F... | Answered on Feb 03, 2014
Make sure your depth guide slider isn't over tightened.
Thats the long shaft sticking out from your drill, you may already know that, but the collar on those tends to bind the chuck bearing if they are overtightened.
Makita HR2450F... | Answered on Mar 24, 2010
Did you check to see if the motor is even being energized.? If not check the switch. If yes, then check motor brushes.
Makita Drills | Answered on Jul 13, 2020
Snap on tools have a very nice cylindrical magnet about 1/4" diameter that will fit inside the end of the chuck. If you release the clamp it should pull out.
Makita Drills | Answered on Jun 04, 2020
you can buy the part
exploded view says part 6
look simple ..?.the way in is undo the top casing
leave the motor section in place if possible
Makita 3700B Trimmer Parts
Makita Drills | Answered on Aug 24, 2019
7.2V LITHIUM-ION 1.0AH (BL0710)
The Makita 1.0Ah battery with a 30 minute charge time.
Lithium-ion (LXT) - Makita
https://www.makitauk.com/lithium-ion-lxt.html
Makita Drills | Answered on Aug 15, 2019
The brushes are probably wearing out. They can also smoke if they get dirt or something on them. You can take the drill apart and replace the brushes, but if they are just burned some, take some fine sand paper or emery cloth and polish the armature where they run and clean the brushes and reinstall.
On the Makita 18-V DC18RA charger, the flashing red light means that the battery is not at the correct temperature for safe charging. If the battery is hot (from use or being in direct sunlight), charging will begin when the battery cools down. If the battery is cold, then charging will start when the battery warms up. (Note: the cold battery could have moisture condensation issues. This could delay the start of the charging cycle.) Home Depot has the manual for this charger here: https://images.homedepot-static.com/catalog/pdfimages/35/35393127-7c0b-4668-8609-9104ae7cc187.pdf . I suspect that Makita uses the same "code" on all of their chargers.
I hope this helps.
Makita Drills | Answered on Jun 25, 2019
You can try to recharge batteries and see if they work by placing them in tool. If you are using Ni cad batteries and charger, you would better served by going lithium ion batteries.
Makita Drills | Answered on Jun 07, 2019
Makita HR2450F Rotary Hammer Logo
Popular Tags
8 questions posted
Top Makita Drills Experts
efs_perpends
efs_perpends
John Trevino
epangan29
Are you a Makita Drill Expert? Answer questions, earn points and help others
View Most Popular
Makita Drills
  • Makita Drills
Most Popular Question
wanted free makita hr2450 manual
  • Drills
