20 Most Recent Briggs Stratton H7159 & Stratton® 5500, 10 HP Generator Questions & Answers
a 10W-40 should work fine. Probably about 2quarts or less.
Briggs Stratton... | Answered on Mar 02, 2015
it sounds that the gasket was not put on properly and the engine leaked all the oil out of it causing it to lock up no lubrication.
Briggs Stratton... | Answered on Feb 20, 2015
You have to unbolt the rubber wheel that goes against the metal disc first.
Sounds like you have remove and disassemble the carburetor and clean it.
You have unloosen the bolt slightly that holds the armature to the engine and since they are tappered fit put a piece of wood on the nut and hit the center with a hammer.
The gap is .010. You can also use a card to gap the coil and after you tighten the coil and remove the card turn the flywheel by hand one revolution to make sure the magnet does not rub on the flywheel.
That is not possible. The oil and fuel systems are seperate. It is possible that the floar on the carb is stuck and fuel drained from the tank to carb, then into the crankcase.
Briggs Stratton... | Answered on Sep 25, 2014
The needle valve on the carbureator float is stuck open or has a little debris stuck in it. You will have to take the bowl off and clean out the seat for the needel valve. A Qtip or small wooden dowel works best.
Briggs Stratton... | Answered on May 23, 2014
check your eingine compression, sounds like it is worn hence the rough idle and loss of power under load
Briggs Stratton... | Answered on Feb 05, 2014
if the piston rings have snapped. as they can do. it can lock the piston in place. and you will need to bore out a piston bore and put in a sleeve and new piston. worst possible thing is the crank has snapped. other possible is the generator motor has seized up making it so the engine will not move.
Briggs Stratton... | Answered on Jan 23, 2014
if theres gas in the tank and fuel line to the carb,then the needle and float valve is gummed up in the sediment bowl below the carb
Briggs Stratton... | Answered on May 01, 2013
Briggs Stratton H7159  & Stratton® 5500, 10 HP Generator Logo
64 questions posted
Top Briggs Electrical Supplies Experts
John Trevino
jdthefixer
rlev_7
Level 1 Expert
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Briggs Electrical Supplies
Most Popular Question
gasoline in mixed oil
  • Electrical Supplies
