20 Most Recent Coleman Powermate 5000W Home Backup Generator #PM0435 Questions & Answers
plug in a electric drill into the generator. start the generator and let it idle. depress the trigger on the drill with the drill set in the forward position and by hand turn the drill in the opposite direction. it should excite the generator and start the drill
Coleman... | Answered on Aug 06, 2013
Please check : - your coil for malfunction and - power supply goes to your coil.
regards, jay
Coleman... | Answered on Feb 21, 2011
Double check your brush istallation. positive side toward rotor bearing, if you put 12 vdc directly into brush pack and check with a meter at the 120 vac outlet and have low or no voltage, you may have no resistance in your rotor slip rings, excitor & main windings also need a resistance check. 12.6-16.7 ohms (rotor) 2.26-2.80 ohms (excitation) .26-.32/.28-.35 main or power windings. Note: unit running when appling 12 volts to brush pack. 2-5 second only, ( This test tells you the rotor & stotor are ok )
Coleman... | Answered on Feb 03, 2011
Not sure what you mean by "plugnit into circuit"
This is a stand alone unit into which you plug the devices that you wish to power. It should have standard recepticls for your devices.
If you are talking about attaching it to your residence, that will require a cutover switch that will disconnect the outside hydro source while the generator is plugged in. That's a job for a certified electrician.
Coleman... | Answered on Feb 01, 2011
There is no such thing as "remagnatized" thats horrible and stupid advice. Your engine once started turns an alternator, which that produces electricity. Check all wiring connections first, if everything looks okay, you may need to replace the alternator.
Coleman... | Answered on Aug 09, 2009
if your plug and outlet are 4 blade, two blades will be flat, the black will connect to one flat blade and the red will connect to the other flat blade,makes no differance to which,the white will connect to the middle blade with a silver color screw terminal,the others will always be brass in color!,the green will connect to the blade that is either "L" shaped or round.looking at the male plug from the blade side it looks like a crows foot,top left blade will be at 11 oclock,right blade will be at 1 oclock,these two are critical, one must be black the other must be red, center is white, other is green. good luck.
Coleman... | Answered on Feb 20, 2009
Take the pulley to any auto parts store and they should be able to match it up. good luck.
Coleman... | Answered on Jan 26, 2009
It is possible that while the bike was laying down that oil or fuel entered the cylinder and is now causing a hydro-lock. With the spark plug out, pull the crank a lot of times. Check to see if fluid comes out of the spark plug hole. Also check to see if the plug is wet or damaged. If you can, look into the cylinder with a light.
Coleman... | Answered on Sep 04, 2020
You need a manual so you can check the rpm, brush gear, circuit and check the rotor is receiving enough current to produce the rated output.
Coleman... | Answered on Aug 08, 2020
Midwest USA... A working generator in good running condition should sell for around $0.05 a watt +-, so 7500x0.05= $375. Excellent condition add a penny. NOS add another penny.
A working generator in poor condition 3 cents/watt.
A generator that doesnt work, i.e. engine doesn't run or engine runs but no electrical power is $0 to $50. Repair costs of some generators cost more than a new one.
As for operational status, the typical shop vacuum makes a handy load tester. The shop vac load along with a "Kill A Watt" power monitor will provide an independent voltage and frequency analysis.
Be sure to plug the vacuum into every outlet and if any outlet doesn't work consider the unit non-working.
Coleman... | Answered on Jul 24, 2020
Contact Powermate direct. That is a bad fault which can severely damage everything in your house connected to it. They will work with you to rectify that fault and supply free parts
http://www.powermate.com/service.php
Coleman... | Answered on Jul 11, 2020
the carb must be clogged then. remove and clean all the passages clean clean clean. use fresh gas and stabiliser always...i suggest seafoam. it works great
Coleman... | Answered on Jun 13, 2020
You can ask it from your supplier
Coleman... | Answered on May 25, 2020
Check all fuses.
Try the lamp test and make sure all panel lamps light.
Check battery voltage is 12.3VDC or greater.
Coleman... | Answered on May 20, 2020
Check the sears parts site with your model number and get a part number, then search with the part number for the best price....
Coleman... | Answered on May 13, 2020
you can get a motor manual from briggs website with your model and serial numbers ready. id also assume coleman has an owners manual
Coleman... | Answered on Apr 21, 2020
Because the battery supplies the power for the ignition!
The alternator that it has just charges the battery.
Coleman... | Answered on Mar 29, 2020
Coleman Powermate 5000W Home Backup Generator  #PM0435 Logo
13 questions posted
Top Coleman Electrical Supplies Experts
Sheldon Dedek
Tim Venetis
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Coleman Electrical Supplies
Most Popular Question
coleman powermate starter pulley broken
  • Electrical Supplies
