20 Most Recent Porter Cable 10,000 Watt 20 Hp Portable Generator #H1000IS W... Questions & Answers
2answers
10,000 watt porter cable generator will not
Why generators do not generate electricity 1. Fault phenomenon When the generator set speed reaches the rated speed, the AC exciter stator excitation circuit switch is closed and the voltage regulator is adjusted to the maximum value when the generator speed reaches the rated speed. 2. failure cause The generator core remanence disappears or is too weak, the newly installed unit is disturbed by long-distance transportation or the generator is placed for too long, the generator core remanence disappears or the remanence inductance is weak, which results in the generator remanence voltage vanishing or less than the normal remanence voltage value.
10/25/2018 4:04:13 PM • Porter Cable... • Answered on Oct 25, 2018
0answers
0answers
0answers
2answers
Cat chewed the wiring harness
H1000IS-W-1
http://members.rennlist.org/Warren/wiring_diagrams.pdf
The wiring diagram on page 22 of this manual is color correct. You should be able to safely use this diagram. It is the best one I have seen. It is best to locate the wires do the resistance checks per the chart on page 9 below and then make your connections. I know I could connect the wires using this diagram no problem.
http://www.msservice.net/pdf/generator_repair_steps.pdf
See page 9 about red to green and black to orange resistance readings and the 2 pink capacitor stator wires:
I just hope this works for you. If you need more assistance feel free to ask for help here.
This is who answered your question:
http://blog.fixya.com/index.php/2010/05/award-winning-service
Thanks for choosing FixYa.
Kelly
12/19/2012 6:21:14 PM • Porter Cable... • Answered on Dec 19, 2012
Produces no power
Check for a blown fuse or any loose wires
2/8/2011 2:41:19 AM • Porter Cable... • Answered on Feb 08, 2011
I have a porter cable
high idle screw or governer
9/9/2010 12:29:22 AM • Porter Cable... • Answered on Sep 09, 2010
Low voltage, freqency appears erractic but engine
called hunting. Adjust the air fuel ratio crew until it stabilizes, The tur idle to specs.
11/19/2009 11:21:17 PM • Porter Cable... • Answered on Nov 19, 2009
720 hours and she is
your engine is siezed up, a condition often caused by not having adequate oil in the crank case. The problem could be relatively minor or quite serious. the only way to find out is to get it torn apart. if this is outside of your knowledge base then i would call a few mechanics or ask at a few auto parts stores.
8/22/2009 8:25:14 PM • Porter Cable... • Answered on Aug 22, 2009
2answers
Porter-Cable generator won't power anything; engine runs, low rpm
You have a simple problem and it has nothing to do with the octane, honda's love better gas, thats all I use in all my equipment and even my 4000 psi pressure washer runs better and cooler with higher more efficient octane, Your problem is in the carb, clean and service it, make sure the air breather is clean (soap and water only if it is a foam unit and do not spray it with any oil) then check for water in the gas by draining the tank into a large clear glass container 1/2 gal at a time. and after all this is done and needs to be done anyway, change the spark plug run the unit and make sure the throttle up solenoid is adjusted properly or even working if this unit is equipped with one. good luck
5/7/2009 2:48:58 PM • Porter Cable... • Answered on May 07, 2009
Idle control inop
Check the small relays first, lightly tapping on them wile on may tell you the one that is bad but not all ways , if thats not it,Pull the circuit board and test or have a old tv repairman test the Diode's/resistor's on the board, if you find a bad one and do not know how to read the rating, take a digital close up picture of it and email it to one of many people selling diodes or resistor's on Ebay, buy it , solder it in.
2/5/2009 8:17:14 PM • Porter Cable... • Answered on Feb 05, 2009
Porter cable CTE 300 OIL TYPE
The Porter-Cable CTE 3000 generator uses SAE 10W-30 motor oil.
3/19/2023 3:12:55 PM • Porter Cable... • Answered on Mar 19, 2023
My porter cable 7500 watt generator does not consistently produce 220 volts it fluctuates below 220 why is that
Usually dependant upon load and RPM of engine.
9/24/2021 6:33:38 AM • Porter Cable... • Answered on Sep 24, 2021
I have a porter cable generator CTE3000, need to know the type of oil to get thanks
You can contact your supplier who supply the generator to you. They know details about their product.
12/31/2019 8:50:10 AM • Porter Cable... • Answered on Dec 31, 2019
Where is the oil drain plug on a Porter Cable BSV550-W located?
What is a BSV550-W
6/11/2019 6:18:41 PM • Porter Cable... • Answered on Jun 11, 2019
Porter Cable BSV 750-W Brushless Generator does not shut off completely, it continues to idle low and sputter when attempting to turn off
Hello Karen, suggestion, when you turn off the generator, previously disconnects the electrical load that is feeding and verifies if it continues with the problem It could be in need of maintenance I sent you the link so you can download the user manual I hope you can solve your concern Greetings Franco Dosil Hola Karen, sugerencia, cuando apagues el generador, previamente desconecta la carga electrica que esta alimentando y verifica si sigue con el problema Podria estar necesitando un mantenimiento Te envio el link para que puedas descargar el manual de usuario Espero puedas resolver tu inquietud Saludos Franco Dosil Porter Cable BSV750 Instruction Manual
4/30/2019 4:54:48 PM • Porter Cable... • Answered on Apr 30, 2019
I have a porter cable generator BS1525 it is putting out 186 volts what is the problem is it the gs0873 compacitor?
Check engine speed first. It is likely too fast. If you have an ability to check frequency of output voltage, do so. It should be ~60hz in USA
10/17/2017 3:12:03 AM • Porter Cable... • Answered on Oct 17, 2017
Fuel flooding carb and getting in oil. What can I do?? 6500 watt 13hp porter cable
Overhaul the carb, make sure the float hasn't sunk and see that the brass valve attached to it is sealing completely in it's seat.
10/25/2016 2:40:08 AM • Porter Cable... • Answered on Oct 25, 2016
Porter Cable 10,000 Watt 20 Hp Portable Generator #H1000IS W... Logo
Popular Tags
18 questions posted
Top Porter Cable Electrical Supplies Experts
Jay Finke
Jay Finke
CJ Rock
CJ Rock
ADMIN Andrew
ADMIN Andrew
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Porter Cable Electrical Supplies
Most Popular Question
cat chewed wiring harness
  • Electrical Supplies
