20 Most Recent Porter Cable Cable 12800 Riptide Saw Blade: 7-1/4", 18-Tooth, RightTilt, Thin Kerf Questions & Answers
You have a rip saw that has a cable with a fuzzy picture?
If this is a cable TV question, two things come to mind ... TV is out of adjustment or you have some ground wires touching your center conductor on your RG-59 or RG-6 cable (or just came to mind - you have split the signal so many times there is no signal).
You can use a cable tester to test the quality of the cable ... you can cut off the ends and replace them. More likely than not, unless you have pro tools and ends (F fittings) you will not get much improvement from this. If you are guilty of multiple splitters in the line, reduce the number of splitters.
If this is a saw question, I dont understand your trouble.
Porter Cable... | Answered on Oct 05, 2009
There are several how to videos on that item posted on youtube. Also the overhaul kit comes with instructions and special tools that you may need
Porter Cable Air... | Answered on May 29, 2020
https://www.ereplacementparts.com/repair-center/article/7451/How_to_Install_an_Overhaul_Kit_in_a_Porter_Cable_Nail_Gun.html
Porter Cable Air... | Answered on Apr 18, 2020
Odds are you have a brad or part of a brad stuck in the slide. Use a flashlight & another brad or paperclip to remove the piece of nail that is blocking the slide.
Porter Cable Air... | Answered on Oct 24, 2019
Uses 23 Ga. headless and slight head pin nails from 5/8" to 1-3/8" length
You need to oil the gun. Put a drop or two on the nail driving mechanism too.
Try lubing the head valve orings with white grease instead of oil. The issue is caused when the head valve orings do not seal perfectly. Lube and retest with no more than 100 psi. Good luck with your repair
Porter Cable Air... | Answered on Aug 27, 2019
I find that a nailer will fail to discharge due to lack of lubrication. Try lubing the head valve orings with white grease instead of oil. If no joy, remove the nails and remove the trigger so that you can fire the gun using just your finger. With trigger pin exposed, connect air hose with 100 psi. Very quickly depress the trigger pin all the way in. If the gun discharges most likely the safety foot and actual trigger is not pushing trigger pin all the way in. If the gun still does not discharge then most likely firing valve spring weak or valve defective. Good luck with your repair
This usually occurs when the check seal is out of place or bent driver or driver is too loose /too tight in the cylinder. The check band is usually the problem. Remove the cylinder and make sure that the black rubber band is covering a series of holes about mid section of the cylinder. If the band is in place, then problem is piston driver is bent , too loose /tight in the cylinder. Good luck with the repair.
This usually occurs when the head valve is worn, cracked or just needs lubrication. If the valve looks ok, then lube with white grease and test. If still no joy, make sure that the trigger firing pin is being pushed all the way in when attempting to fire. Make adjustment to safety foot. Good luck with the repair.
This happens due to lack of lubrication. The air that runs thru the regulator is very moist and caused the internal parts of the regulator to rust. With no air pressure in the tank, take the regulator apart and lube the threads on the adjustment knob. Also remove the plug on the rear of the regulator and lube the plunger valve. You may find that the valve is stuck to the plug. Separate the valve from the nut and clean / lube. You may also find that the regulator is too far gone and needs to be replaced. Good luck with the repair.
This happens when the driver is not returning to top of the cylinder. Remove the driver and make sure that it is not slightly bent or not lubed enough and sticking to the cylinder. Also check the driver piston seal ring is not too loose. The driver should move easily within the cylinder but not so loose that it just drops to the bottom of the cylinder. Good luck with your repair.
I find that the trigger valves in these guns are reliable and that most problems with random fire is lack of lubrication and adjustment of the safety foot. Assuming that air does not leak when you connect air supply and leaks from trigger when attempting to fire. This indicates a lack of lubrication of the head valve. Remove the head valve and lube with white grease.
Test the gun, of ok then you are done. If no joy, then check safety foot for adjustment. How to test if the safety foot is the problem.
Remove the nails, remove the trigger leaving exposed the trigger firing pin. Adjust air supply to 100 psi and connect to gun.
Assuming no leaks quickly depress the trigger valve pin all the way in. If the gun fires then the problem is with the safety foot and or the actual trigger is not pushing the firing pin all the way in when attempting to fire. Make adjustments accordingly. Good luck with your repair.
The fr350a is completely different from fr350. The fr350a is completely modernized framing gun as compared to the retired version. I do not like repair kits because you are replacing parts that are still good. Instead replace parts as needed. If you state the issue you are having I may be able to recommend the actual part needed. If however you do not have any major air leaks, a lube job will make the gun work great. Use white grease or nail gun oil. Good luck with your repair.
The part that you are looking for is most likely the "piston stop."
this part can be found at Dewalt service centers as they own Porter Cable. Also some Ridgid nail guns use the exact same parts as Porter Cable. Good luck with your repair.
Porter Cable Air... | Answered on Aug 26, 2019
Moisture and oil in small amount is normal with oil type compressors, a by product. If there is no air leak between the pump and tank, suspect worn piston rings, worn out faulty valves, loose pump head.
Porter Cable Air... | Answered on May 18, 2019
I never use mine in the driver setting, always in drill mode. The reason is the clutch won't last and while the motor rotor revolves, the chuck head will not have torque and won't work no more.
Porter Cable Air... | Answered on May 14, 2019
There should be a pressure switch that can be adjusted. You should be able to adjust high pressure shut off and at what pressure you want it to restart. If you give me a model number I can help further.
Marty
Porter Cable Air... | Answered on Apr 25, 2019
Porter Cable Cable 12800 Riptide Saw Blade: 7-1/4", 18-Tooth, RightTilt, Thin Kerf Logo
5 questions posted
Top Porter Cable Air Tools & Compressors Experts
Joe Garcia
Joe Garcia
JOHN LAPIER
J Rosado
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Porter Cable Air Tools & Compressors
Most Popular Question
cable plugged in but picture fuzzy
  • Air Tools & Compressors
