20 Most Recent Coleman Powermate Portable Generator PM0435003 Questions & Answers
Yes, If there is room I would use a spst toggle switch. This is a very common switch. Try ebay, HD etc. If there isn't a similar switch can be found at ebay. Good Luck
Coleman... • Answered on Oct 14, 2017
10w -30 will be fine
Coleman... • Answered on Aug 10, 2017
Does the flywheel magnet still have a strong pull on it?
Coleman... • Answered on Mar 21, 2017
You cannot, speed is propertional to voltage on these, as they have capacitor voltage regulation. Do not use this for powering home appliances, it is common to see this design and not a problem. If you add load and it will decrease but so will the frequency
Coleman... • Answered on Jul 10, 2015
Check the Coleman Service manual which is available at
Coleman... • Answered on Nov 07, 2014
The carburetor needs to be rebuilt - the float valve is stuck open.
Coleman... • Answered on Jul 27, 2014
It generally has a long rotor through bolt accessibile from the generator end, this forces the generator rotor onto a tapered shaft on the engine. Once removed the through bolt slide a long bar ion the hole and screw the bolt back in, that will force it off the taper
Coleman... • Answered on Nov 29, 2013
I would put anything that screws into it
Coleman... • Answered on Nov 28, 2013
Engine speed is too high, and/or excitation capacitor is bad
Coleman... • Answered on Nov 23, 2013
Take the through bolt out of the end of the alternator / rotor shaft. it is a long bolt. The shaft from the engine is tapered and unlikely to just pop off. Find a bolt that will screw into the end of the rotor shaft (hardend) find a metal bar that will slide into the rotor long enough so the bolt tightens down on the bar, it will pop the alternator off the tapered shaft
Coleman... • Answered on Nov 18, 2013
where i can get a Coleman carburator powermate 5000w
Coleman... • Answered on Jun 10, 2013
a 10-30 multi weight oil should work fine, in the winter, if it gets cold there, a 5-30, if it gets super hot in summer, a 10-40
Coleman... • Answered on Mar 10, 2013
Coleman Powermate Portable Generator PM0435003 Logo
89 questions posted
Top Coleman Electrical Supplies Experts
Sheldon Dedek
MrJunk
Level 1 Expert
Jay Finke
Jay Finke
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Coleman Electrical Supplies
Most Popular Question
separate engine from generator powermate
  • Electrical Supplies
