20 Most Recent Palm Treo Pro Smartphone Questions & Answers
i have a palm treo from sprint, how do i create a slideshow?
Palm Treo Pro... | Answered on Mar 06, 2020
Others haev to pair their phones with yours. then only would you be able to send or receive. What you do is ask your friend to put his BT on as you do yours. Ask him to select a music file and select option send. he will get a choice and should select BT. He will get the list of BT enabled devices and your phone will be listed there. Ask him to select your name. When he does send the file to you you will get a notice asking you that so an so is sending a file to you. should you accept. Accept. And the download will start. Cheers.
Palm Treo Pro... | Answered on Jan 06, 2017
These steps will erase all data from the device. You may want to synchronize if possible before trying these steps.
1. Take the back panel off to expose the reset hole.
2. Press Power to turn on the screen.
3. While pressing and holding End, use the tip of the stylus or a small paper clip to press and release the Reset button.
4. Continue pressing and holding End until the Erase all data? prompt appears.
5. Press Up.
6. Wait for the progress bar on to fill up, then you can use the device again.
hard reset Palm Treo 680,755,700p,800w,...etc
There is no reset button on this models like other Palm devices, so performing a hard reset can be tricky.
How to hard reset your this types ?
1. Disconnect the Treo from a charger or USB cable.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/End while you insert the battery.
4. When the screen lights up with the logo appears, release Power/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo is hard reset.
Palm Treo Pro... | Answered on Sep 07, 2012
try this:
connecting to an open network
1 press wi-fi on the side of your smartphone
if it says Wi-Fi is on your phone will detect available networks.if your device does not auto connect and configure wireless networks screen appears highlight the network you wamt and press connect
Palm Treo Pro... | Answered on Aug 27, 2012
The following steps will erase all the information from your phone, if possibly try to sync your phone first.
5. Press Up.
Palm Treo Pro... | Answered on Dec 18, 2011
Try turning the Palm Treo off using a Soft Reset.
  1. Save your work and close all active programs and games.
  2. End wireless connectivity by holding down the red "End" button for 5 seconds.Take off the battery door cover.
  3. Remove the battery from the Treo.
  4. Press and hold down the red "End" button for five seconds to drain the memory.
  5. Insert the battery back into the device and replace the battery door.
  6. Wait for the Palm Powered logo screen to appear. The preferences screen will appear and prompt you to enter the time and date.
If you encounter data loss after a soft reset there is a serious hardware malfunction and your device must be serviced.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Palm Treo Pro... | Answered on Sep 22, 2011
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Palm Treo Pro... | Answered on Jul 26, 2011
Try to do this simple step:
1. Copy the underlined link below and paste it to the address bar of your browser. You'll see the manual for your smartphone. I hope this helps you solve your problem.
http://www.retrevo.com/support/Palm-m130-PDAs-and-Handhelds-manual/id/281ci262/t/2/
Palm Treo Pro... | Answered on Jul 14, 2011
Here you can download all you intirisuyuschiyu literature. And download the user guide. http://kb.hpwebos.com/wps/portal/kb2/na/treo/t850/unlocked/downloads/page_en.html http://palmone.r3h.net/downloads.palm.com/documentation/treopro/treoproT850UNA_UG.pdf
Palm Treo Pro... | Answered on Jul 01, 2011
Contact service provider. You will need unlock code from them.
Palm Treo Pro... | Answered on Jun 08, 2011
You can determine the time that you've received a certain message by just looking upon on a specific message in your phone and browse it..there you can see the time it was sent and the time you received it..thanks.
Palm Treo Pro... | Answered on May 28, 2011
The Treo Pro is a different phone than the 700w. Here are two links to Palm's website with support information on both phones.
http://kb.palm.com/wps/portal/kb/na/treo/700w/verizon/home/page_en.html
http://kb.palm.com/wps/portal/kb/na/treo/t850/alltel/home/page_en.html
Palm Treo Pro... | Answered on May 14, 2011
Welcome to Fixya. To be able to fix the issue just click on the link below. It will provide the steps on how to reset the phone.
Palm Support
If you have questions please let me know. Thanks for using Fixya.
Palm Treo Pro... | Answered on Apr 08, 2011
the ear piece of the phone is not working it needs to be changed for now use loudspeaker or earphones
Palm Treo Pro... | Answered on Mar 20, 2011
Either the charger port on the phone is faulty or the charger itself. Try a different charger if you can and if this works, the dock is faulty, if it doesn't then its the phone. Pretty simple repair and most Treo repair centres will be able to do it.
Palm Treo Pro... | Answered on Mar 17, 2011
Palm Treo Pro Smartphone Logo
Popular Tags
126 questions posted
Top Palm Cell Phones Experts
Ed
Ed
Marvin
Marvin
Jax Planet
Jax Planet
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Treo Palm
  • Treo Palm
Most Popular Question
need manual download
  • Cell Phones
