20 Most Recent
Eljer TITAN 15" Two-Piece Toilet - 091-0755/Choose Color=Ru Questions & Answers
Water line stain
Try a product called Iron Out. You can use it for a lot of different types of stains that build up in toilets, dishwashers, washing machines, etc. You can get it at any hardware store. I'm in PA, though, so I don't know if it's available in all states. This worked for me, but the minerals in your water may be different than mine and it may not work the same for you. Good luck!
Toilet is leaking between tank
Check for any loose connections or a crack in the pump casing. Check all the rubber fittings also for any holes or cracks.
I've only had this toilet for a year. This
Make sure the water shut off valve is on. Turning to the right shuts it off so turn it to the left. Maybe one of the kids shut off the water stranger things have happened. Check your supply tube also it could be stuck especially if you have hard water in your area.
Motor doesn't turn on.
Do you have the model number? A lot of these systems use a pneumatic tube to send air pressure to a switch. If you have one of those, make sure the tube is not loose or cracked.
2/20/2016 4:51:35 PM •
Eljer Home
Answered
on Feb 20, 2016
Air switch stuck
A sticky air button can be one of two issues.
- The Air Button can simply be worn out in which case it obviously needs to be changed. Measure the size of hole once it is removed and then you will know what size you need to reinstall.
- The inside of the Air Button may have some calcium built up inside where the button goes up/down. If you can get the center button up and removed then you can take some soft emery cloth and gently run around the outside edge of the button and the inside of the air button body. This will gently remove any calcium deposited there and allow the button to go up and down easily.
Rod
US Parts Center888-521-6183
7/17/2015 1:20:39 PM •
Eljer Home
Answered
on Jul 17, 2015
50 GCM listed section fitting hydro bath hbs
This sounds like you are referring to the suction cover. The fitting with all the little holes in it.
These are removed by taking the two screws out of the face of the suction cover and removing it.
You can then clean it and install it back the same way.
US Parts Center
6/6/2014 3:20:57 AM •
Eljer Home
Answered
on Jun 06, 2014
