20 Most Recent Coby CT-P8600 Cordless Phone (CTP8600) Questions & Answers
Try taking the battery pack to your local radio shack store. They can usually match the original battery pack with a new, compatible one even if they no longer make the EXACT one that came with the phone. This recently happened to me with a panasonic phone bought around 2002. phone stopped charging, no longer make the phone, etc. I went down to radio shack and they fixed me up with a new battery (not exact brand/part number as original) and it worked. Hope this helps you.
Coby CT-P8600... | Answered on May 20, 2011
Could this be remote control rather than a Coby Lands Phone?
https://cobyusa.com/products/universal-remote
Coby Lands... | Answered on Nov 15, 2018
hi there.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. ... If theCD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.31 Mar 2015
How to Fix a CD Player That Skips ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-a-cd-player-that-skips
Why does a CD player skip?They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.12 Aug 2005Buyer beware: to fix a CD that skips, first try good old soap and water ...www.telegraph.co.uk/.../Buyer-beware-to-fix-a-CD-that-skips-first-try-good-old-soap-an...Search for: Why does a CD player skip?
How do you fix a CD player that skips?Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lenscleaner.12 Jul 2010How to Troubleshoot a CD Player - YouTubehttps://www.youtube.com/watch?v=xAlPb7NBvz4Search for: How do you fix a CD player that skips?
or try this link for more help if you need it.
cd player skips Google Search
Coby Lands... | Answered on Nov 27, 2017
if your line is being shared with a computer on a modem, install the correct filters for both the phone and the modem
Coby Lands... | Answered on Sep 09, 2017
Al firmware updates come with an instruction.
I hope you did read the instruction, before you updated in the first place.
For every update there is a condition, the electronic needs to work perfect and the battery / power supply must be capable of delivering enough power during the whole update process.
When an electronic device is start acting strange, a software update is the worst thing you can try to solve the problem.
If there is an update for your phone, why should I type the instruction here? it is in the package and you should read it before. not when the phone is bricked.
Coby Lands... | Answered on Jul 25, 2014
my cell can neither acess messaging nor the internet. what are the courses and the likely solution
Coby Lands... | Answered on May 22, 2013
whitch type problem specify first? program memory ......... what massage?
Coby Lands... | Answered on May 17, 2012
Yes you can replace the coby dvd 224 remote with a new one, all you need to do is to get a replacement remote that looks exactly the same as your old one. You can try out that of a friend before you go ahead in replacing it with a new one. Be sure that the problem is not that the battery of the remote is weak and needs replacement or the sensor on the device you use the remote for and the remotes sensor is not bad before you can replace the remote.
Test the sensor by opening the device to check if the pin that is holding the sensor light is not rusty, if it is, then it is the light you are to replace, check the same on the remote to see if the problem is from the remote, then you replace the sensor light which is the infra red light on both the remote and the device itself.
Hope this information helped you. Thank you for using fixya.
Coby Lands... | Answered on Jan 18, 2011
Your microphone may be faulty. If you can drop it back to where you got the phone they should sent it for repair for you
Coby Lands... | Answered on Jan 14, 2011
now, should i assume that the current problem is ringing.. or what..the lost numbers.
refer to this manual for further details.
Regards
Coby Lands... | Answered on Feb 27, 2010
Remove all phones from the system except the one which is on the main incoming line. Unplug base unit, remove batteries from the handset and then reinstate.
Does it work?
Yes: plug each unit back in one at a time, testing as you go.
No: Disconnect and put a simple phone on the line, a wired one. If that works, your line is fine, your phones aren't.
Have you paid your phone bill? They cut you off, the number is still live, but inactive.
Manual in case you need it.
GIGASET A120 USER MANUAL Pdf Download ' ManualsLib https://www.manualslib.com/manual/651632/Gigaset-Gigaset-A120.html
Gigaset A120/A120A/A220/A220A Display keys: The base station at a Pressing a key launches the function that appears above glance that key in the display. The handset at a glance Display Function when pressed 1 Charge status of the batteries: = e V U ¢... Page 2: Safety Precautions Use only the power adapter supplied, as indicated on the devices. Check the pack contents One Gigaset A120...
Lands Phones | Answered 18 hours ago
Caller ID on landlines is a paid service.
Some mobiles supply the information by default.
Some people and companies withhold their numbers because they don't was callers phoning back to extensions within the business.
Lands Phones | Answered Yesterday
You can't. The issue is with the 1471 line answering system and not your phone.
Lands Phones | Answered 3 days ago
Google
(make and model of phone) set up
Impossible for us to guess and there are so many phone systems in use.
Lands Phones | Answered on Sep 10, 2020
Here's some suggestions from the Vtech site:
If the battery(s) has been in service for more than one year....
As a rechargeable battery gets older, its ability to hold a charge decreases. If your battery has been in service for more than twelve months, it may be a good idea to replace it.
If you are replacing the battery and you need assistance, visit our Battery Finder link. If a battery for your model is unavailable, you can search the Internet using the key words cordless phone batteries for an on-line supplier. If you prefer to purchase locally, you can look for a replacement battery at your area consumer electronics retailers. It is recommended that you take your present battery with you to insure your replacement is the correct size and has the correct plug (where applicable) and specifications (for example - 3.6v 400mAh Ni-Cd). Caution when replacing batteries
If your model takes individual cells, do not use non-rechargeable batteries. Use only the recommended rechargeable batteries as prescribed in your User's Manual.
If the battery(s) has been in service for less than one year....
If the handset shows any sign of life (any lights; characters on the display screen; sounds when keys are pressed), your handset is not dead, making it unlikely that a new battery will fix the problem. Consider the following:
Is the base unit getting power?
If your base unit is not getting power, your handset is not charging. Tip: Do not plug your Base Power Adaptor into an electrical outlet controlled by a switch (for example, a light switch on the wall or a power strip with an On/Off switch).
If your battery pack is the plug-in type, is it securely plugged into the handset?
Disconnect, and then reconnect the battery plug to ensure a good connection. In addition, make sure the battery cover is on securely.
Do you see any charge indicators on the base or handset?
Depending on your model, the handset and/or base will have indicators to let you know when the battery is charging. Check your User's Manual for details.
Remember, if the handset shows any sign of life (any lights; characters on the display screen; sounds when keys are pressed), then is not dead, making it unlikely that a new battery will fix the problem. Try the following reset procedure:
Reset your Phone
If your telephone is not operating normally, disconnect the battery(s) from the handset and disconnect power from the base. After a few minutes, connect power to the base, install the battery(s) and cradle the handset in the base to allow it to establish a link. You can now try using your phone again.
Lands Phones | Answered on Sep 08, 2020
I might be broken then and has stopped working
Lands Phones | Answered on Sep 03, 2020
Coby CT-P8600 Cordless Phone (CTP8600) Logo
1 questions posted
Top Coby Lands Phones Experts
NOEL
NOEL
Harrie
Tom Chichester
Are you a Coby Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Coby Lands Phones
  • Coby Lands Phones
Most Popular Question
ctp8600 cordless
  • Lands Phones
