20 Most Recent Peerless Industries Peerless Wall Mount Faucet Kitchen/bar/mop Sink Questions & Answers
0answers
I need to buy a new one, where do you purchase
They have Peerless faucets at Lowes.
11/11/2010 7:19:57 AM • Peerless... • Answered on Nov 11, 2010
Need to know how large a hole to drill into wall
If you can't find any documentation, the manly(easy) way would be to buy a hole saw set, find the part of the faucet that goes through the wall, and select the closet fit possible of hole saw that will fit the part. It's okay if the hole's a little bigger than the pipe because the cover plate will probably cover it up, but please double check before drilling that the hole really will be covered by the coverplate.
11/2/2009 8:51:45 AM • Peerless... • Answered on Nov 02, 2009
2answers
Need to buy a peerless wall mount kitchen faucet
Peerless happens to be a less than preferred brand. If you go to www.peerless.com, you will find the model type. Try it, you may be able to order it online. haven't seen it around.
good luck.
10/12/2009 12:16:05 AM • Peerless... • Answered on Oct 12, 2009
I just bought a house and the garbage disposal is
Home Depot sells a disposal wrench that you use from the top side. When it's held, it looks kind of like a T but the top part will pivot so it will go into the opening. You can use it to try and turn if from the top. If this doesn't work, then replace it.
4/9/2009 4:59:55 AM • Peerless... • Answered on Apr 09, 2009
Wiring diagram or owners manual for a PEERLESS LUH 75 Heater.
Will find on line, seach for then download!
11/4/2018 5:39:10 AM • Peerless... • Answered on Nov 04, 2018
The perimeter of a square is between 500cm and 520cm. how long each side be?
divide by 4. 500 divided by4= 125
3/1/2015 9:58:58 PM • Peerless... • Answered on Mar 01, 2015
3answers
Peerless sink plug is clogged with hair. How do I
The plug is held in place by a rod that connects to the plug lever. Look under the sink where this rod enters into the drain. The rod is held in place with a cap that is screwed onto the drain pipe. Unscrew the cap, pull out the rod, and the plug with then lift out.
On some sinks, the plug can be twisted to release it from the plunger rod, you simply twist it until it unhooks. It it does not twist, then folow the first set of directions
1/21/2015 1:57:44 AM • Peerless... • Answered on Jan 21, 2015
THE HANDS ON MY SEIKO MELODY CLOCK WILL NOT MOVE WITH BATTERIES REPLACED?
Please don't type in all CAPS, it is considered SHOUTING and is harder to read. Sounds like the new batteries weren't any good. https://www.google.com/search?q=HANDS+ON+MY+SEIKO+MELODY+CLOCK+WILL+NOT+MOVE+WITH+BATTERIES+REPLACED ..
3/29/2023 9:11:57 AM • Home • Answered Yesterday
How can I find a lid for Toto 612T-33 toilet tank ?
notify manufacturer or online search
3/27/2023 11:14:32 AM • Home • Answered 3 days ago
My Porcelanosa toilet seat cover loose
Pictures can be added by clicking the button that says 'Photos'. Navigate to the image and insert it. You can add Videos as well, see below.
3/25/2023 10:56:14 PM • Home • Answered on Mar 25, 2023
Grundfos Wastemate doesn't pump lowest enough. can I replace the pressure switch. Does anyone supply them?
I used to host works dinners for Grundfoss in Leighton Buzzard, in the UK. They are great for spares and for aftersales support. https://www.google.com/search?q=grundfos+wastemate+parts+diagram ..
3/24/2023 3:02:58 AM • Home • Answered on Mar 24, 2023
3answers
What can I do about cockroaches in my home?
Cockroaches thrive in warm areas with plentiful access to food and water. The best home remedies for getting rid of them are:
  • Clean your home thoroughly to make sure there is nothing for them to eat, such as crumbs on the floor
  • Keep your home cool to discourage them from entering
  • Seal up cracks. Cockroaches can live in small cracks in concrete, so seal your home properly to stop them entering
  • Use home poison-bait solutions such as a mixture of powdered sugar and boric acid.
If none of that works, it's time to bring in the professionals. I tried all of the above in my home in Tonbridge a few years ago before I gave up when nothing seemed to work. Fortunately, after I called out this company offering pest control in Tonbridge, the problem disappeared overnight and I haven't seen a cockroach since!
3/23/2023 3:23:48 AM • Home • Answered on Mar 23, 2023
After the Summer Time change the clock keep running without adjusting to the real time?
Question edited for clarity. Questioned moved from Misc to clocks. All questions need full 'make model (what it is)' as the first three words or it is all guesswork. My guess is that you are in the wrong time zone and it will change in 2 weeks when it changes in the UK. You are set to GMT instead of PST, CT or EST. ..
3/18/2023 7:26:49 PM • Home • Answered on Mar 18, 2023
Peerless Industries Peerless Wall Mount Faucet Kitchen/bar/mop Sink Logo
7 questions posted
Top Peerless Industries Home Experts
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Peerless Industries Home Expert? Answer questions, earn points and help others
View Most Popular
  • Peerless Industries Home
Most Popular Question
need buy peerless wall mount kitchen
  • Home
