20 Most Recent Jado 827-850-144 Shogun Single Lever Kitchen Faucet with Pull Out Spray - B... Questions & Answers
faulty cut off to faucet , calcium ,'
Jado 827-850-144... | Answered on Jan 29, 2018
Is this a new or used faucet
Jado 827-850-144... | Answered on Aug 28, 2017
I looked at spec. sheet but found nothing for temp. adjustments so I would have to say try turning up water heater a little at a time.
Jado 827-850-144... | Answered on Oct 01, 2009
you have to locate the water shut off valves before you attempt removing the water lines, hopefully they will be located on the lines under your sink, if not you will have to shut the water main off coming into the house. After you have shut the water off and disconnected the lines, look under your sink at the back were your faucet comes through the sink and you will find the fasteners, unscrew these counter clockwise and the faucet will lift out .
Jado 827-850-144... | Answered on Sep 03, 2009
Hi, most pull out sprayers have the hose hanging under sink, the one you had to pull to retract. They come with a weight that is to be installed at bottom of loop with sprayer in "parked" position. If there is no weight, that's the problem, if there is, make sure there is nothing in the way of full movement of this hose when it pulls into the parked position. It can sometimes also be something like a wood splinter, clamp, screw, pipe or other obstruction rubbing against your hose keeping it from falling properly (as longg as that weight is on it). Let me know if this helps! Thanks
Jado 827-850-144... | Answered on Jun 17, 2009
After removing the set screw near the bottom of the body (#12 in parts diagram), turn the faucet over and tap the body (the bottom of the shiny body where it contacts the countertop) with a hammer while holding onto the hoses, the body will slide off, so don't let it drop.
Jado Plumbing | Answered on May 21, 2020
If he knew how to disassemble the faucet but it was corroded so badly it would not come apart<?>... sometimes a Dremel with cutting wheel is the only option.
If he wasn't familiar with "JADO"... ask JADO to help identify your faucet.
http://www.jadousa.com/default.aspx?aspxerrorpath=/searchResults.aspx
Get the technical documents yourself and then find a different plumber.
Jado Plumbing | Answered on Mar 09, 2019
vinegar and old toothbrush to work it in the threads. let sit for a few minutes. repeat.
keep trying gently.
try tightening it a TINY bit before unscrewing.
vise-grips with rag wrapped around.
Jado Plumbing | Answered on Jan 16, 2018
Use a block of wood and a couple flat head screwdrivers
carefully pry up on the faucet handles using the wood as leverage. But do not force them, heat up with a hair drier first before removing.
Jado Plumbing | Answered on Jan 14, 2018
It will require two people one to hold from top and underneath using deep socket remove nut.
Jado Plumbing | Answered on Nov 21, 2017
cartridges are one piece unless
cartridges replace the insert and tap washer
Jado Plumbing | Answered on Oct 29, 2016
Is it a star socket maybe?
Jado Plumbing | Answered on Sep 28, 2016
Sounds like you installed the cartridge incorrectly. The orientation is important to note when removing the old unit. Try pulling it out and reversing the orientation. Check the inlets and match them up.
Jado Plumbing | Answered on Dec 26, 2014
Please find your faucet on the link below or close to your faucet. That way I may help you fix the problem. I am a general contractor and know all faucets on the market. I just need to know the model # to help you more.
http://www.jadousa.com/searchResults.aspx?d=1&t=36
Jado Plumbing | Answered on Jun 08, 2011
sounds like the o-rings inside the valve cartridge are bad. turn off valves and remove the cartridge and take it to your local hardware store or plumbing repair shop to match up and buy a new one.
this should solve your problem.
if you have further questions about this problem ,, please feel free to ask.
c...
Jado Plumbing | Answered on Jan 30, 2011
Jado 827-850-144  Shogun Single Lever Kitchen Faucet with Pull Out Spray - B... Logo
12 questions posted
Top Jado Plumbing Experts
ray gallant
Marvin
Marvin
Are you a Jado Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Jado Plumbing
  • Jado Plumbing
Most Popular Question
jado kitchen faucet no pressure
  • Plumbing
