20 Most Recent Moen ShowHouse S711 Waterhill Single Handle Kitchen Faucet with Matching Si... Questions & Answers
Moen kitchen faucet leak from spray
This might mean that the diverter in that controls the sprayer needs replacing. It is located behind the valve body underneath the tub spout sleeving
2/23/2010 10:41:45 PM • Moen ShowHouse... • Answered on Feb 23, 2010
Moen Waterhill Bridge S713NL. How to replace cartridge? Can't get handle off?
Question edited for clarity and add CAPS. Here is the parts breakdown. Your model is discontinued. The hand lever unscrews, the part that holds the handle looks like a push fit and then there is a screw collar holding the cartridge. Increase Zoom to 200%. https://assets.moen.com/shared/docs/exploded-parts-views/s713pt.pdf It looks like they disagree with me, and their way is easier!
F Cashman
· a year ago
I need to remove the faucet handle to fix a leak and I don't know how to remove the handle -please help
  1. Moen Plus Support · 11 months ago Hello F Cashman and thank you for your interest in Moen products. The handles for the Moen Waterhill Chrome Two-Handle High Arc Kitchen Faucet are removed by holding the lever stationary, while unscrewing the base of the handle hub counter-clockwise to remove the complete handle. If you have additional questions, please do not hesitate to contact us directly. https://solutions.moen.com/Article_Library/Kitchen_Handle_2H%3A_Threaded_Hub
Faucet Cartridge Replacement ' Customer Support
Moen https://www.moen.ca > customer-support > cartridge-re... This 1248 Cartridge does not have a Removal & Installation Video. Feel free to contact us or call us for assistance at 1-800-BUY-MOEN (1-800-289-6636). Missing: Bridge ‎ S713NL
MOEN https://www.moen.com > products > Waterhill-Chrome-... The Moen S713 Waterhill Two-Handle Traditional Bridge ... HOW DO YOU REMOVE HANDLES TO REPLACE CATRIDGES? 1 ... Cartridge Replacement · Faucet Finder · Return ...
MOEN https://www.moen.com > products > Waterhill-Chrome-... ... Waterhill Two-Handle Kitchen Bridge Faucet. We ... HOW DO YOU REMOVE HANDLES TO REPLACE CATRIDGES? 1 ... Cartridge Replacement · Faucet Finder · Return Policy. Rating: 3.3 · ‎ 24 reviews Missing: S713NL ‎' Show results with: S713NL
3/16/2024 10:59:21 PM • Moen Plumbing • Answered on Mar 16, 2024
Moen Positemp Shower - little or no flow after several years?
Test the flow of water with the showerhead removed (through the shower arm). If you are getting good flow through the shower arm- clean the showerhead to remove any debris and replace if necessary. If there is still no flow, replace the cartridge. Sep 22, 2020
Shower Faucet: Low Flow-PosiTemp Valve - Moen Solutions
1/20/2024 10:05:40 PM • Moen Plumbing • Answered on Jan 20, 2024
I replacrd my moen 1225 cartridge & now only the side sprayer works
recheck your work --improper install or wrong/ defective part
8/27/2023 9:36:30 PM • Moen Plumbing • Answered on Aug 27, 2023
3answers
Water pressure is good on sprayer but only trickles out of spout this is on a Moen kitchen faucet
Check the aerator, or replace it could be plugged
12/10/2022 7:24:32 PM • Moen Plumbing • Answered on Dec 10, 2022
Philips screw that holds parts to 1225 cartridge just turns, stripped? how do I get that out
you can try to tap handle loose and pull up on it to remove crew. Personally I would change faucet and supply lines, and not not look back.
11/17/2022 1:38:07 AM • Moen Plumbing • Answered on Nov 17, 2022
2answers
Moen motion sensor faucet
Check the power to it, battery or transformer unit. Ensure that the data cable and power source cable (battery pack or AC adapter) are plugged in tight and secure. Check Batteries: If using a battery pack, ensure the batteries are installed correctly and are snug in the battery holder. Loose batteries can cause the faucet to operate erratically. Sept 24, 2020
Sensors Not Working - Moen Solutions
https://solutions.moen.com > Article_Library > Sensors_N...
A
10/21/2022 8:00:45 AM • Moen Plumbing • Answered on Oct 21, 2022
Can;t find set screw tto remove on moen single handle kitchen faucet. it;s not a cap cover that pulls off.
moen dot com go there the manual for it is there, all mine are. some are very tricky, RTM read the manual costs ZERO to read. and is best for sure if tools are needed, or other odd things. no 2 valves on earth are the same zillions, models unless are.
8/6/2022 3:51:31 PM • Moen Plumbing • Answered on Aug 06, 2022
2answers
Moen quick connect leaking under sink
you either do not have it seated all the way or you have damaged an o-ring anytime you are putting togethr parts with o-rings you should make sure and put stem grease on the o-rings to ensure not to cut or damage them. if you have damaged the o-ring instead of a whole new part you can take the o-ring out take it to your local hardware store and match it with a new one. dont forget the stem grease.
1/23/2022 2:02:13 AM • Moen Plumbing • Answered on Jan 23, 2022
3answers
New moen CA87520CSL faucet just installed and
Look around in the box and your work area it sounds like the rubber seal is not in the connector.
1/19/2022 4:59:10 AM • Moen Plumbing • Answered on Jan 19, 2022
3answers
Moen 1225 Cartridge for kitchen faucet
I have no experience with modern quarter-turn taps as I prefer the ease and economy of traditional tap washers. I do have lots of experience with O rings of various types. Most commonly O ring breakage is due to the wrong size being used - diameter and/or section. when machined metal parts are fitted together and sealed with an O ring the clearance between the parts is very small - just enough to allow a sliding fit. The O ring(s) generally locate in a groove, sometimes on the end face but mostly around the diameter. O ring sizes are chosen to completely fill grooves on the end face without either stretching or compressing the rubber. Grooves around the diameter require similar consideration though some stretching is needed to assemble them; once fitted the rubber should not be under either tension or compression. The chosen section of the ring will allow the groove to be filled when the components are fitted together therefore when they are separated it will seem the O ring is too thin for the groove. If the correct size is used with carefully machined components and suitable lubrication applied during assembly there should be no difficulty. O rings are available in a number of different materials from soft natural rubbers to fairly hard synthetic materials. I suggest you carefully measure the components and compare your results with the supplied O rings.
11/22/2021 7:21:09 PM • Moen Plumbing • Answered on Nov 22, 2021
I need this repair kit M100429, Lowes sales said Moen has lifetime guarantee on parts
Email moen with the part number and picture if poss they should post at kit out to you
7/20/2021 5:58:32 PM • Moen Plumbing • Answered on Jul 20, 2021
Moen single andle pullour faucet has the undercounter spacer/plate has gotten wet and rusted and is falling apart. need a replacement spacer/washer.
Go to moen.com custom support and you can look up your faucet there. If it is discontinued they will help you with a replacement..
2/10/2021 2:56:19 AM • Moen Plumbing • Answered on Feb 10, 2021
Moen kitchen faucet started to drip moen model 7786. is there a gausket to be replaced. what to do ?
In all honesty the easiest fix is to call moen and they will and they will send a new faucet to your door step with no charge. It is a cartridge you have to replace inorder to cure the leak. It a moen cartridge part # 1224 should you choose to replace it. Assuming this is a Monticello 2 handle faucet. Hope this helps!
2/10/2021 2:44:10 AM • Moen Plumbing • Answered on Feb 10, 2021
Shower valve. Why is it difficult to rotate either way?
contact moen for replacement parts. have your model number ready
11/19/2020 4:28:54 PM • Moen Plumbing • Answered on Nov 19, 2020
Bought our retirement home from the original owner that installed all Moen throughout. The sprout on dispenser broke off at base. Is this under warranty.
Yes moen do life time warranty contact moen and they will send you one out
11/5/2020 1:20:58 PM • Moen Plumbing • Answered on Nov 05, 2020
Moen ShowHouse S711 Waterhill Single Handle Kitchen Faucet with Matching Si... Logo
Popular Tags
1 questions posted
Top Moen Plumbing Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Moen Plumbing
  • Moen Plumbing
Most Popular Question
moen kitchen faucet leak from spray
  • Plumbing
