20 Most Recent Delta 473-WHSD-DST Saxony Diamond Seal Technology Single Handle Kitchen Pul... Questions & Answers
Go to hardware where your faucet is sold and determine what screw you need. The red/blue dealy is just a screw cover.
Delta... | Answered on Feb 28, 2010
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Delta... | Answered on Dec 10, 2008
  • Solid Blue - Normal operation, "Touch" mode is activated.
  • Flashing Blue - Normal operation, the hands-free mode is activated.
  • Solid Red - Warning mode - Replace batteries as soon as possible. While the water is running Solid Red LED is illuminated. When the water is off, the Red LED flashes once every 5 seconds. The faucet operates normally, solenoid valve is open.
  • Rapid Flash Red - Alert Mode - Battery Failure Imminent. The Red LED flashes once a second. The first time the faucet is used, the Red LED will turn ON, the solenoid valve will be opened and remain open. The manual valve must be used until the batteries are replaced.
  • Solid Red - Lockdown Mode - Replace Batteries. Extremely Low Batteries - The RED LED is ON, and water will not flow. The solenoid valve is closed and faucet will not operate until batteries are replaced.
  • Long Flash Red (2 seconds on / 2 seconds off) - Board error, replace electronics kit, RP53230 See manual bypass of electronics section of Installation instructions.
Delta Plumbing | Answered on Jul 19, 2020
https://www.youtube.com/watch?v=unqc06D5Q6Q
Delta Plumbing | Answered on May 08, 2020
For me, the issue was the washer that's exposed on the underside of the circular brass piece that's exposed when you unscrew the top (I wasn't able to find any documentation that explains what anything is called). My washer looked fine, but I removed it, added some silicone o-ring lube i had and re-assembled. Stopped leaking.
Delta Plumbing | Answered on Oct 12, 2019
https://www.deltafaucet.com/files/live/sites/delta/files/company/concierge/Touch_troubleshooting_guide.pdf
"Ifthesesolutionsarenotabletoresolvetheissue,pleasecontactourDeltaTech2O ConciergeTeamat1-844-923-5368
IFNOSOLUTIONABOVERESOLVESTHEISSUE,PUTFAUCETINMANUALMODEBYUNPLUGGING THEBATTERYBOXWHILETHEWATERISRUNNINGUNTILRESOLUTIONCANBEACHIEVED"
Delta Plumbing | Answered on Jun 09, 2019
You need to install the screw that came with item, it goes under the handle thru the extension and into cartridge. Refer to instructions.page 3.
qk5krxajihraoapoi3zsan40ueqbvcpnowdvswq5rplcc5jjjt9xtd0q73fiheilr206ekaef1bbswnqkaf4ggaabui7kgbwcaadeaaaafvpkvylsawb+ibgaa+ig8cwcqbqibaaa6yjjomwucgc8qdqaaaabebkqdaaaaajeb0qaaaabazea0aaaaabazea0aaaaarazeawaaaacradeaaaaaqgranaaaaaaqgranaaaaaeqgramaaaaakqhraaaaaebkqdqaaaaaebkqdqaaaabebkqdaaaaajeb0qaaaabazea0aaaaabazea0aaaaarazeawaaaacradeaaaaaqgranaaaaaaqgranaaaaaeqgramaaaaakqhraaaaaebkqdqaaaaaebkqdqaaaabebkqdaaaaajeb0qaaaabazea0aaaaabazea0aaaaarazeawaaaacr8f8dkgsefmplxo4aaaaasuvork5cyii=
https://media.deltafaucet.com/MandI/88723%20Rev%20B.pdf
Delta Plumbing | Answered on Jun 05, 2019
Open the battery case and realign the batteries with the positive and negative poles in the right positions according to the layout in the battery compartment. Close the battery compartment. Make sure it locks completely before continuing.
Locate the reset button, if any, on or near the battery compartment, after changing out batteries.
Push the red reset button to reset the faucet.
Test the faucet to ensure the reset corrected the problem.
Tip
Not all automatic faucets have red reset buttons. Some faucets just require inserting new batteries or realigning the batteries in the compartment to complete a reset. on the faucet. Check the instructions that came with your automatic faucet or locate the user's guide online at the manufacturer's website.
Delta Plumbing | Answered on May 08, 2019
There is normally a filter at the end of the faucet outlet. They usually unscrew. its usually a fine mesh screen with a plastic backing mount.
Delta Plumbing | Answered on Mar 22, 2019
Delta 473-WHSD-DST Saxony Diamond Seal Technology Single Handle Kitchen Pul... Logo
6 questions posted
Top Delta Plumbing Experts
Bill Johnson
Bruce Robin
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Delta Plumbing
  • Delta Plumbing
Most Popular Question
delta kitchen faucet mixed
  • Plumbing
