20 Most Recent Delta Faucet Delta 172-SSWF Waterfall Single Handle Kitchen Faucet with Matching Side Sp... Questions & Answers
If you are talking about the aerator at the end of the spout,take a pair of pliers and a rag put the rag on the aerator and turn counter clockwise(take care to make sure rag is covering all the area and that should help you get it off.If you plan on replaceing aerator which is about $6 just take the pliers and take it off.
Delta Faucet... | Answered on Apr 27, 2016
i forget what the piece is called exactly but if you go to home depot or lowes or where ever and give them the type style and brand of your faucet and tell them what it's doing they will set you up with the new part. it's sort of a core type piece with rubber o-rings on it
Delta Faucet... | Answered on Jul 16, 2012
Well it most likely only need lubed but if you are going to take it apart to do that you may as well go with new parts. Witch ever you decide be sure to use what they call plumber lube it is made just for this purpose and will last longer then say WD-40. If you live in an are that has real hart water then plan on doing this every year or so.
Delta Faucet... | Answered on Feb 11, 2011
delta customer service or a plumbing supply house
Delta Faucet... | Answered on Feb 02, 2011
I can fix this.
What is the last thing you did before this problem started?
Delta Faucet... | Answered on Jan 13, 2011
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Delta Faucet... | Answered on Dec 13, 2010
Delta Faucet Delta 172-SSWF Waterfall Single Handle Kitchen Faucet with Matching Side Sp... Logo
54 questions posted
Top Delta Faucet Plumbing Experts
Muntejaya Ginting
Muntejaya Ginting
Bill Johnson
Marvin
Marvin
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • Delta Faucet Plumbing
Most Popular Question
any tricks lifting spout off base
  • Plumbing
