20 Most Recent Price Pfister Marielle Kitchen Faucet with Pull-Out Spray ... Questions & Answers
2answers
When installing do you silicone each piece for
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
11/22/2012 12:49:49 PM • Price Pfister... • Answered on Nov 22, 2012
Valve closes by itself when at less than full on
This usually is an indication of wear on the cartridge, the rubber o-rings and what not, they tend to get a little sticky. Best thing is to contact Price Pfister and have them send you a new cartridge with the install instructions if you don't already have them. Price Pfister is great to deal with and should provide these things to you at no extra charge as there is a lifetime warranty on their products. Their number is 1-800-PFAUCET (1-800-732-8238). Good luck.
8/26/2010 7:28:03 PM • Price Pfister... • Answered on Aug 26, 2010
I do not have any
I had a same problem with a Price Pfister pull-out-head kitchen faucet. I determined that the blockage was in the end of the hose nearest the head, so I drilled out the inside of the hose, which cleared the blockage. However, when the faucet is used and then shut off, the water now takes forever to stop flowing. I have since found out that there is a low-pressure check valve inside the end of the hose to prevent that, which I destroyed. Try disconnecting the hose at both ends, and blowing it out from the head end.
5/22/2010 3:40:28 PM • Price Pfister... • Answered on May 22, 2010
5answers
Price Pfister Marielle Kitchen Faucet with Pull-Out Spray - can't
hi ralphpos,
that part is called the ball lever assembly, you can remove this through a pressure / suction ball wrench.
the video below from discovery channel will show you how to assemble / dis-assemble the faucet.
http://www.tv.com/How+It%27s+Made/Dress+Forms-Boat+Propellers-Duvets-Faucets/episode/1232418/reviews.html
hope this helps,
regards,
voodoo
5/10/2009 10:07:04 AM • Price Pfister... • Answered on May 10, 2009
4answers
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
1/9/2022 10:19:46 PM • Price Pfister... • Answered on Jan 09, 2022
I have a price pfister single handle kitchen faucet How do I adjust the water temperature? Water is not hot enough
It has to be adjusted at the water heater.
12/30/2018 10:09:43 PM • Price Pfister... • Answered on Dec 30, 2018
Need diagram for price pfister bath clean out
10/8/2018 2:05:41 AM • Price Pfister... • Answered on Oct 08, 2018
Price Pfister Marielle, 26 series, leaks around the top of the spout body when water is turned on. How do I take it apart and fix the leak?
1 under the sink turn off both water supplies 2 disconnect the supply lines at the on/off valve EZer than at faucet 3 under sink unscrew the retaining nut(s) 4 on top wiggle or pry the faucet and lift up and remove. 5 know you can replace the spout and don't forget the new O ring that's why it leaks anyway. you really just need the new washer O ring . 6 Reinstall check for leaks 7 caulk around faucet. Hope this helps Mike
5/31/2018 8:08:37 PM • Price Pfister... • Answered on May 31, 2018
Have Price pfister kitchen faucet...the hot water has slowed to a trickle. Not the source -plenty coming in and after replacing cartridge with new from Price Pfizer-no change. Any ideas?
Back to the basics...did you turn the hot water shutoff back on? Is it a multi-turn shutoff or a 1/4-turn one? If it was old, and multi-turn, the washer could be shot, and it is all clogged. Try disconnecting the hose and see if you can get any flow into a bucket from the connection. There could be some crud caught inside of the cartridge, so you might need to remove it and flush it out. Price Pfister single handle sink faucet no hot water
2/12/2018 4:05:50 AM • Price Pfister... • Answered on Feb 12, 2018
MY PRICE PFISTER 533-50 HAS
No be sure water is off. Take this apart with still being supplied will cause you a lot of trouble, wife will be very unhappy. aaaaaelftksuqmccaa==
12/30/2017 11:21:09 PM • Price Pfister... • Answered on Dec 30, 2017
Buying a replacement part for price pfister a cartridge #21137. Kitchen faucet 15 years old.where can I buy onr Is there a new part #?
take the old one to the store with you they can match it up.. (home depot... lowes)...
10/2/2017 6:27:33 PM • Price Pfister... • Answered on Oct 02, 2017
I have a slow drip on my bathroom faucet. how do i
Full instructions with diagrams here:
http://home.howstuffworks.com/home-improvement/plumbing/how-to-repair-a-faucet1.htm
very detailed and should help you stop that annoying drip..drip...drip
Hope this helps, if so please leave feedback. If not let me know and I'll try and help some more
6/14/2017 1:21:12 PM • Price Pfister... • Answered on Jun 14, 2017
My kitchen Price Pfister faucet is starting to "squeak" when I turn it on or off. What's up?
dry rubber "O" ring/ threads on the shaft call a plumber to pull it apart , replace the seal and lubricate it
12/4/2016 2:29:01 AM • Price Pfister... • Answered on Dec 04, 2016
3answers
How do I fix a leaky Price Pfister Treviso 49D faucet.
Download the instructions from the manufacturer.
7/27/2016 8:50:11 PM • Price Pfister... • Answered on Jul 27, 2016
How do you remove the aerator housing from the Price Pfister hanover double handle bathroom sink faucet
most aerators are screwed into the faucet IF you use a pair of multigrips with clothe folded in the jaws , you can apply gentle pressure and turn it out too much pressure and you will distort the aerator so be gentle with it
6/1/2016 11:52:07 PM • Price Pfister... • Answered on Jun 01, 2016
What causes noise when water turns on
are you speaking of water hammer ? as typically this occurs when shutting off water , faucets that make noise like a whistle when on could be a part clogged aerator in the end of it , this happens over time and debris is aloud to collect in end of faucet
2/20/2016 2:44:45 AM • Price Pfister... • Answered on Feb 20, 2016
Need manual for Price Pfister Flow Matic wall mount kitchen faucet
Go to manufacturer web site for manual download.
11/5/2015 1:48:42 AM • Price Pfister... • Answered on Nov 05, 2015
Price Pfister Marielle Kitchen Faucet with Pull-Out Spray ... Logo
9 questions posted
Top Price Pfister Plumbing Experts
Marvin
Marvin
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • Price Pfister Plumbing
Most Popular Question
when installing silicone each piece
  • Plumbing
