20 Most Recent
Moen Monticello Single-Handle Kitchen Faucet with Cathedral Spout .... Questions & Answers
Repair moen single lever faucet
All Moens are the same- so no matter what model u have- u do the same thing. U have to pull the valve out. It's very hard to pull. It may take several tries- don't be afraid to pull. My husband is a plumber. He said they're difficult to get out. U just have to pull. Hope this helps! Good luck!
Moen 7700 cartridge replacement
This is the exploded view. The cartridge is available at any hardware store.
http://www.moen.com/shared/docs/instruction-sheets/ins111a.pdf
I have a single-handle Moen
Yes you should have a lifetime warrenty. Call 1-800-buy moen for replacement parts. They generally are very good about taking care of their productc however be prepared for a extended wait to get through. You can buy after market or genuine moen part at most lowes or ace hardware stores. Hope this helps. Thank you
Moen balancing spool
Moens balancing spool moves back and forth inside the cylinder to regulate flow of water to keep you from getting scalded. If it is not working properly you can get to much of hot or cold water coming out of the spout....or low to no water coming out.
Need to replace O Ring but cant pull the spout off
there might be a allan screw holding it down usually located at the back of the faucet if not there is a chance that there is a screw on escutcheon just above the base of the spout this should screw off with a strap wrench.
Moen 7400 fix
http://www.moen.com/shared/docs/instruction-sheets/ins111a.pdfIf you mean part #16 in the blow up diagram, assembly number 15 must be fully seated for the clip to enter and seat.into part 17.
Ever since my Moen kitchen
There may be construction debris or residue partly blocking the aerator. Have you unscrewed the end and cleaned it out? Sometimes the fellow may not have assembled the aerator in the right order and a simple rearranging of parts will clear it up.
Regards, farmerbear
Moen cathedral keeps coming loose
tighten the lock down nut under the sink , also,, unscrew the cap (at the base of the spout,, and Lube the O ring ( with either plummer grease if you have it, or if not with vasoline) this should cure your problem
No Hot water coming out
Cartridge removal is a simple matter of exposing and pulling out the old cartridge. Before getting started, turn off both water valves underneath the sink and allow the water to run until the line is clear. Using a screwdriver, gently pry off the cap on the lever of the faucet handle to expose the cartridge. Remove the U-shaped retaining clip that holds the cartridge in place and pull the cartridge out. If dirt or residue makes removal difficult, use a Moen cartridge puller to assist you. A cartridge puller fits over the cartridge and gives you greater pulling power.
Soak the dirty cartridge in vinegar for four hours and replace.
If cleaning the cartridge does not work, call the Moen Helpline at 1-800-465-6636 or Customer Service at 1-800-465-6130 to order a free replacement. Locate the part number on the cover page of your instruction manual. If you no longer have the manual, look on the underside of the spout.
How do I clean the
If you are talking about the areator you can remove it by turning it to your right . You can remove the screens and brass disc and clean them with soft brush and cleaner like mild C.L.R. and water solution. This will clean lime and mineral scale from them. Do not use this on outside finish. Use softscrub and soft cloth to clean. If the finish is too badly discolored you can get replacements at most hardware stores or for special finishes go to moen.com for location of dealer nearest to you. To install just reverse steps. I hope this helps you. Thanks
