20 Most Recent Brother DCP-7030 Digital All-in-One Laser Printer Questions & Answers
brother dco 7030 print unable 72 troubleshooting and routine maintenance
Brother DCP-7030... | Answered on Mar 03, 2018
What worked for me was to follow the instructions in this video: Resetting lever on cartridge There is a lever on the left hand side of the toner cartridge (left hand side - with you holding the cartridge as if you were going to insert it into the printer). It seems that lever has to be at the '12 o'clock' position to tell the printer that you have a new cartridge. The video showed the person removing 3 screws and then ensuring the lever was at the '12 o'clock' position. On my cartridge I had to do some wiggling to get the lever to move as it's gear assembly seemed to want it to only move down to the '4 o'clock position' and then stay there. Eventually I got it moved to 12 o'clock - and when I stuck the toner back into the printer - the 'toner end of life' message went away. I then removed the toner cartridge - as I wanted to try another cartridge that I had also reset the lever on. I found that lever had again moved to the 3 or 4 o'clock position - after printing just one test page so I am guessing it being at the 12 o'clock position tells the printer you have a new cartridge - and then it moves over to the regular position at 3 or 4 o'clock..
Brother DCP-7030... | Answered on Jun 29, 2016
that's not a problem, the printer warns you when your toner is soon to end. Get a new cartridge to replace it when it is all used up. Tip: Toner warning comes on early, you can get more pages out by taking the drum out and shaking it carefully.
Brother DCP-7030... | Answered on Mar 30, 2015
what is drum end soon problem solve
The Drum must be replaced It cannot be reset. There is a chip inside which configutres the default page counter. regular and high yield drums available http://www.bizrate.com/ink-toner-inkjet-cartridges/brother-dcp-7030-drum/
Brother DCP-7030... | Answered on Feb 13, 2015
> toner life end
Replace (not refill) the toner-cartridge.
Brother DCP-7030... | Answered on Nov 29, 2014
All electronic equipment with some intelligence in it, can be rewetted, by switching it off, removing the power cable and then connect and switch on again.
The machine should start the internal "program" from scratch.
In the manual it says you should leave it off for several minutes, if you want to initialise the copier again.
Brother DCP-7030... | Answered on Jun 10, 2014
OPEN THE FRONT COVER OF YOUR PRINTER AND SELECT YES ON LCD PANEL. ERROR GONE ....ENJOY..
Brother DCP-7030... | Answered on Dec 11, 2013
Print Unable EC / BROTHER DCP-7030
Brother DCP-7030 Digital All-in-One Laser Printer Logo
154 questions posted
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
View Most Popular
DCP Brother
  • DCP Brother
Most Popular Question
print unble 72
  • Office Equipment & Supplies
