20 Most Recent
Haier HL32R 32 in. LCD TV Questions & Answers
Direct tv cannot find a code to program direct TV remote
Hi
The following codes should work with your model
12293,13382 ,10178 ,10000 ,11034
S
etup Instructions
- Turn on the TV manually or using the original TV remote.
- Press and hold the "Mute" button and the "Select" button on the direct tv remote at the same time until the green light on the top of the remote blinks twice.
- Using the number key, enter the first digit of the code above. Wait for the green light on top of the remote to flash twice
- Enter the remaining 4 digits of the code as above.
- Aim the remote at your TV and press the "OFF" key once. Your TV should turn off. If it does not turn off, repeat the steps above, trying each code until you find the correct code.
www.electro-medical.blogspot.com
Haier tv model le32f2220 will not come on has 120v ac to it
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
My remote control for Haier tv stopped working, despite good batteries
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
How to get channels to stay scanned?
After an auto-tune function, all the received channels should be set in its memory. If not, be sure that the main system control memory IC is damaged and should be replaced. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box.
