20 Most Recent Sony BRAVIA KDL-26N4000 26 in. HDTV LCD TV Questions & Answers
If you post a picture that would be easier and I may be able to locate the cable for you. Other than that there is a couple of places to check. One would be LPAV out of St. Paul, MN. They deal with nothing but used/older equipment and have tons of that stuff. The other would be allied electronics. If they do not have a premade cable but have the ends and you need further help I could probably make one for you.
Sony BRAVIA... • Answered on Jan 28, 2014
The question is if model number correct is picture a little or a lot dark?
Sony BRAVIA... • Answered on Aug 28, 2012
A blue screen usually indicates that you are on an input with nothing hooked up to that input.
Sony BRAVIA... • Answered on Aug 08, 2012
You can unplug it for a while, but probably worn out and cheaper to buy new at walmart.
Sony BRAVIA... • Answered on Jan 03, 2021
No signal is being detected at the air/cable input terminal.
Sony BRAVIA... • Answered on Dec 10, 2020
backlight problem
Sony BRAVIA... • Answered on Dec 06, 2020
Hi Sherry, you can test your remote control to see if all the keys work correctly Take your cell phone, put in camera mode and point the emitting LED of the remote control towards the camera, press the keys, one at a time and see if the emitting LED is illuminated, if so, try the volume up key, if the light does not turn on, you could carefully disassemble the remote control and clean the contacts and the keyboard internally rubber, Do not use alcohol to clean the rubber keyboard, you can clean it with warm water and detergent then let it dry very well, the contact plate, you can use a cloth with some liquid to clean the glass, the idea is to remove the rubber residue on the contacts then arm again and test, but you have results consult a specialized technical service I hope you find the suggestion useful Greetings Franco Dosil Hola Sherry, puedes probar tu control remoto para saber si todas la teclas funcionan correctamente Toma tu celular, pon en modo camara y apunta el Led emisor del control remoto hacia la camara, presiona las teclas, una por vez y fijate si se ilumina el Led emisor, si es asi, prueba la tecla de subir el volumen, si no se prende la luz, podrias desarmar con cuidado el control remoto y limpiar internamente los contacto y el teclado de goma, No Uses Alcohol para limpiar el teclado de goma, lo puedes limpiar con agua tibia y detergente luego dejalo secar muy bien, la placa de los contactos, puedes usar un pa?o con un poco de liquido para limpiar los vidrios, la idea es sacar el residuo de goma que hay sobre los contactos luego arma nuevamente y prueba, sino tienes resultados consulta a un servicio tecnico especializado Espero te resulte util la sugerencia Saludos Franco Dosil
Sony BRAVIA... • Answered on Sep 15, 2019
hello Dear this is panel problem please replace panel Thanks M Nasir
Sony BRAVIA... • Answered on Apr 14, 2019
Aron, To perform a reset you will need to disconnect the TV completely from power for at least 30 seconds, if this doesn't resolve your problem then you may have hardware that has expired in your device. Without physically looking at your device I can't say with certainty what your problem is, it could be your PCB. There are video's online you can visit on how to test a PCB for faults. If you are not comfortable troubleshooting your device I would suggest contacting a local electronic repair shop near you, however I will link you to a generic instructional video showing you how to perform basic troubleshooting of your device. Hope this helps, Best regards https://www.youtube.com/watch?v=qxG3hmmvkJs Testing LCD TV Power Supply BoardsSTEP BY STEP fixya-aioep5zungdwqwtpjd23ghga-3-0_0.png
Sony BRAVIA... • Answered on Mar 08, 2019
Although I am just guessing, most Sony equipment uses metric screws. Go to a Home Depot or similar store and take the piece that you have that contains the threaded fittings and they will help you find the screws you need. https://www.manualslib.com/manual/793567/Sony-Kdl-32xbr6.html?page=7#manual This page of the manual gives some info about the screws such as not longer than 1/2" (or 12mm) to prevent damage to the set. Sony customer service may be able to supply replacement screws too.
Sony BRAVIA... • Answered on Feb 18, 2019
Unplug from wall for 60 secounds then plug back in. See if that works.
Sony BRAVIA... • Answered on Jan 19, 2019
Press the HOME button on the remote control. Select Settings. Select System Settings. Select Customer Support. Select Factory Settings. Select OK.
Sony BRAVIA... • Answered on Jan 18, 2019
THe antenna came of. Did you use it and is it giving troubles now? If not, then don't mind and leave it.
Sony BRAVIA... • Answered on Jan 17, 2019
See if remote has a ratio or zoom button on it.
Sony BRAVIA... • Answered on Dec 07, 2017
Sony BRAVIA KDL-26N4000 26 in. HDTV LCD TV Logo
6 questions posted
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
nephew bought new sony bravia lost
  • Televison & Video
