20 Most Recent Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo Questions & Answers
Go to the Tuner setup screen and select cable instead of air. Then put the TV on Channel 3 and connect the cable box to the antenna connector on the TV.
Sharp LC-26DV24U... | Answered on Sep 12, 2016
sounds like maybe something is begining to go. I usually recommend that it is reset to factory default through the menus available from a remote control. If, after resetting, the fault persists it must be something to do with the electronic hardware and the fault shoud be diadnosed by a qualified technician.
Sharp LC-26DV24U... | Answered on Jun 02, 2015
If you are using the ANTENNA input mode of the TV and should be receiving a local station on a properly chosen channel then something is wrong with the RF or IF section inside the TV. If you can connect an external video source to the TV see if that works while selecting the proper input mode.
Sharp LC-26DV24U... | Answered on Jul 01, 2014
I have the same model Sharp TV with the same symptoms. The TV would sometimes work perfectly, then go to white screen (audio OK) and sometimes back to working perfectly again.
I saw Posts saying to check F404 and Q413 - My fuse F404 was not blown, and replacing the Q413 transistor did not fix it.
On Q413 I had about 12.4 VDC on the Emitter, 12.3 VDC on the Base and about 1.5 VDC on the Collector. My service manual called for 11.6 VDC on the Base lead. As a Test, I used a 150 Ohm resistor from Q413 Base to metal chassis ground, and that made the TV work OK.
I replaced the Q419 NPN silicon driver transistor, and now the TV has been restored to 100% proper operation.
I hope that helps someone else down the line.
Sharp LC-26DV24U... | Answered on Jan 24, 2014
Is its a Sharp Remote? or a Generic
A) Check Batteries
B) If a sharp aquos remote there is a function button on the right top side - insure that TV is selected. TV led will light
C) On left side there is a red TV power button press and insure the red led on the remote lights.
D) IF Tv does not turn on then you may have a problem with
the sensor inside the tv.
Only real way of verifying it is not The Remote sensor is by trying another remote. If you have a Cable or Universal follow the instructions for a Sharp TV and try that. If it works problem is with the Sharp Remote if it doesnt its your remote sensor inside the tv.
Hope this helps.
Sharp LC-26DV24U... | Answered on Aug 16, 2013
The Video/ luminance. or the power voltage supply line is not
working. needs repair.
Sharp LC-26DV24U... | Answered on Nov 03, 2012
YOU MAY USE RADIO SHACK TIP31 TRANISTOR PART # 276-2017 IN PLACE OF KTA1281 COST $1.79 WORKS FINE
Sharp LC-26DV24U... | Answered on Nov 17, 2011
If the cc button on your Sharp remote control isn't turning them off then the captions may be coming from your cable box. The hidden menu to access closed captioning on the cable box is usually found by turning it off and then (yes I did say turn the cable box off) then press the menu button on the front of it immediately after turning it off. Then you navigate down to captions and disable them. When you turn the cable box back on the captions should no longer be there.
Sharp LC-26DV24U... | Answered on Oct 27, 2011
It may have failing switched 5vdc transistor that feeds the 5v to the LCD T-CON board.
Here is the service manual: http://elektrotanya.com/?q=showresult&megnev=sharp&megnev2=LC-26DV24U&kategoria=&kat2=all
It has similar to this one as shown here: http://s807.photobucket.com/albums/yy352/budm/Sharp/Sharp%20LC-26SB24U/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Sharp LC-26DV24U... | Answered on Jun 21, 2011
It's the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hoping that the solution will help to solve the problem....
Sharp LC-26DV24U... | Answered on May 14, 2011
Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo Logo
50 questions posted
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
sharp lc 26dv24u black screen only
  • Televison & Video
