20 Most Recent Pioneer Elite PRO-151FD 60 in. Plasma TV Questions & Answers
Reset pioneer tv
I rearranged furniture in my living room, picking up my pro-151fd elite, plugged it in to have no power, tried everything I could think of including an overnight reset. Thought of what could be the common denominator with most of the issues that people have, it's that they picked it up, felt under the front left and turned the tv on. The switch is not labeled, is part of a sqaure protrusion at the very bottom of the tv, 1" to the right of the "Pioneer" label, hope this helps someone who just has a dead tv without the blue flashing lights.
12/15/2020 4:31:00 PM • Pioneer Elite... • Answered on Dec 15, 2020
0answers
0answers
0answers
0answers
Power supply
Be the first to answer 9/25/2013 3:59:54 PM • Pioneer Elite... • Posted on Sep 25, 2013Be the first to answer
White screen
It sounds that the digital processor section to video at the main board is faulty. Contact any service technician.
7/1/2013 9:05:45 AM • Pioneer Elite... • Answered on Jul 01, 2013
Replace cracked panel
If the panel is cracked, it will cost around 2/3rd of the total cost of a new TV. If its protective glass only have broken, it can be replaced for very less cost. Check what happened. Check this link too. It has details about these matters. http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option.
6/25/2013 2:49:39 PM • Pioneer Elite... • Answered on Jun 25, 2013
Red light blinking
How many times do this standby light blinks at one time switch ON? These blinks are fault indications. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. These are called blinking codes. If you wish to get more about these blinking codes, check this link. It has details about these blinks and causes to many brand televisions. To follow and to do repair work to TVs, especially to Plasma displays, you must have sound knowledge in electronics. Anyway, check it. http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option. It will make search easy.
6/25/2013 2:47:00 PM • Pioneer Elite... • Answered on Jun 25, 2013
Pioneer plasma tv picture is cutting off heads
Issue may be adjustable in the Tech menu with your remote---you need to see if you can find the service manual (with schematics and information about getting into that menu and how to adjust).Try to GOOGLE MODEL NUMBER WITH service manual or contact Pioneer.
3/21/2012 2:19:05 PM • Pioneer Elite... • Answered on Mar 21, 2012
TV power shut down, began
Hi garnie868,
This is an indication of out-of-regulation in the power supply section. The very common caused of this fault is the dried-up/leaky electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit and blinking error appear. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Also, bad solder joints can produce the same symptom, it is hard to spot, you should use table lamp/portable lamp for finding the cold solder. Secondary reason of fault is the open fuse/fusible resistor in series with the output of regulator IC/transistor, shorted/openRegulator IC/transistor, shorted zener diode(all are in the power supply section) and the microcontroller. Best that you check the output voltage of each regulator to determine where the fault came from and narrow the job.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
4/16/2011 5:23:37 AM • Pioneer Elite... • Answered on Apr 16, 2011
My tv randomly turns off when connected to cable,
This is most likely your problem, that it only happens with a certain input might very well be a fluke, have your powerboard checked before your tv goes out completely!The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped you (or not) then please rate, thank you! 9fc4049.jpg
2/4/2010 3:15:54 AM • Pioneer Elite... • Answered on Feb 04, 2010
2answers
My Pioneer 5020 unit displays sould level but not picture
Hi, please double check that all of the inputs for the tv are placed correctly. Then, you can remove any accessories (ie video game consoles) before power cycling your tv. Otherwise, you can perform a channel scan next before factory resetting your tv. Thank you.
11/27/2022 9:22:34 PM • Pioneer... • Answered 3 days ago
Pioneer plasma TV model PDP-4271HD. When I turn the power on it starts to come on and then shuts down the blue Power indicator light flashes.
Unless your a skilled electronic tech and have the test gear to trouble shoot the set don't waist your money trying to fix it. Plasma sets are about 10x more complex than a LCD set
8/19/2022 9:59:19 PM • Pioneer... • Answered on Aug 19, 2022
Pioneer Elite PRO-151FD 60 in. Plasma TV Logo
21 questions posted
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
tv power shut down began
  • Televison & Video
