20 Most Recent Sony Bravia KDL-40V4150 40 in. LCD HDTV Questions & Answers
Why does screen have multicolored vertical lines on right side of dispay?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
9/9/2014 4:46:39 AM • Sony Bravia... • Answered on Sep 09, 2014
0answers
0answers
We are having issues with the screen. The display
Sounds like a defective T-Con board, but it is better to test it before replacement. Also there is a possibility to repair it at a lower price. You can find a company that is testing this kind of T-Con boards and repair them here: http://www.coppelltvrepair.com/p/540/repair-service-for-auo-t400hw01-v5-40to2-c06-40t02-c06-lcd-timing-controller-t-con-causing-bad-tv-picture
9/18/2013 10:36:42 AM • Sony Bravia... • Answered on Sep 18, 2013
Blank screen
The fault is with its main power supply regulator section itself. One or more voltage rail is missing. Your TV need a through checkup. Seek tech assistance.
6/6/2012 2:19:14 PM • Sony Bravia... • Answered on Jun 06, 2012
Kdl-40v4150 turn on only 1 min then going black
That's either bad power board or bad main board.
Given the description it is very hard to say which of the two it is.
Frankly, considering you can get a new power board for $25 I think you should just go ahead and do it - it will cost less than bringing the TV to a repairman and as a repairman I can tell you they wouldn't have much better chance than you do...just shoot for a try and this will narrow it down to a single board.
http://cgi.ebay.com/1-876-467-13-Power-supply-/390304148338?pt=LH_DefaultDomain_0&hash=item5adff0ab72
I am not anyhow associated with the above seller. it is just the lowest I could find on eBay.
Hope this helps!
Bobby
5/31/2011 7:04:05 PM • Sony Bravia... • Answered on May 31, 2011
Sony Bravia 46 XBR has the input bar stuck at the top of screen.
Unplug the TV for a while and hopefully, that should reset the circuity. If you're using the original remote control, check for the display button and press it. I would also suggest doing a factory reset if your TV has that feature and if the TV allows you to do it after unplugging it.
9/30/2022 3:10:56 AM • Sony BRAVIA... • Answered on Sep 30, 2022
I need to remove the back off a Sony Bravia KD-48X81J
The front and back pieces are like a clam shell and are compression fit with tabs into one another. You need to use something like a guitar pick or spudger to separate the pieces. Dont use metal objects due to damage that will happen to the plastic .
8/25/2022 5:14:39 AM • Sony BRAVIA... • Answered on Aug 25, 2022
Sony 65 inch TV, KD-65X750F not getting any power from stand-by pin on power board?
Do you get voltage with the main board unhooked?
3/27/2022 11:56:41 PM • Sony BRAVIA... • Answered on Mar 27, 2022
Sony 49 XBR 900 E power will not come on unless the plug is taken out from the set and reconnected. Can you tell me which board should be replaced?
what plug not told./PC is dead?no it is not a PC it is a television posted to wrong forumnow corrected.is TV set to sleep mode, RTM read the manual on TVare the clicker remote batteries fresh>?
3/24/2022 2:55:41 PM • Sony BRAVIA... • Answered on Mar 24, 2022
How can I watch Netflix on a tv Sony wega that isn’t hooked to the internet. It’s wirelessly connected to Vizio ( smart tv Netflix built in) but I want to be able to watch in a different room
netflix is a 100% internet web site , streaming site. thus the net in flix. what did you mean by hooked?\ do you have internet at home at all? do other things in home work to the internet, like PC or cell phones. what I can not under stand is (different room) this phase implies some rooms do work (netflex) and wifi gets weak if my move any TV farther from the home router and will fail past 25 feet or more. wifi is super weak through walls for sure brick, or 2 walls. if home is small one wifi access point is all you need if huge home more. distance matter, TV to router. no TV model # told. (tells me wifi spec) if you said my TV works in room 1 but not room 2, wifi;. it be super more easy to answer.. is this true? if true , get a tech to upgrade your wifi. or go wired, Ethernet.(a better home upgrade)
3/24/2022 2:24:22 PM • Sony BRAVIA... • Answered on Mar 24, 2022
I have a 85 inch Sony Bravia TV. I have sound but no picture
Hello !! what do you mean by you replaced the video card ? mainboard or t-con ? , we need more information
2/1/2022 12:21:49 AM • Sony BRAVIA... • Answered on Feb 01, 2022
Sony bravia 40" kdl-40v3000 stand screws
They are usually M6 or M8. You can get them from Home Depot or Sainsbury Homebase.. These are listed as the correct ones. https://www.ebay.com/itm/4-STAND-FIXING-SCREWS-FOR-SONY-KDL-40U3000-KDL-40V3000-KDL-40D3000-KDL40W3000-TV-/322578615461 and here as well, the same type https://www.ebay.co.uk/itm/272144950454?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338722076&customid=&toolid=10050 ..
11/30/2021 5:53:30 PM • Sony BRAVIA... • Answered on Nov 30, 2021
I have Sony Bravia 32r402a with demo loop running. Also the power light blinks many times thereafter input select tv/hdmi/video keeps flashing. Any action for remedy?
Sounds like a bad main board, or more specific the EEPROM is bad on the main
11/13/2021 8:41:51 PM • Sony BRAVIA... • Answered on Nov 13, 2021
Sony Bravia KDL-40V4150 40 in. LCD HDTV Logo
Popular Tags
18 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
having issues screen display
  • Televison & Video
