20 Most Recent LG 60PG60 60 in. Plasma HDTV Questions & Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
LG 60PG60 60 in.... | Answered on Jun 25, 2016
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. If you wish to get assistance over phone, visit this site. https://www.6ya.com/
LG 60PG60 60 in.... | Answered on Nov 02, 2015
Well... for sure your power board is good!!
One down... 2 to go.
My answers are NOT based on any LG experience... but I can tell you after 50 years on the leading edge of MOST electronics... the biggest challenge you will have is finding how to open your case.
... and KEEPING track of which screws go where...
DO KEEP TRACK... Do unplug your device & be safe!
Do a quick read up on ELECTROSTATICs... but unless you are in a dry windy location simply putting on a wrist strap is unnecessary.
ALWAYS Ground your hands before you ever touch any electronic components.
Check the bus cables and connectors in between the boards... here a reseat process can help... but be extremely careful. Use a really good magnifying glass or even a jewlers loop to make sure you are seeing if it is indeed a plug, locked or keyed plug or a special retainer clip... plug. Some are simply attached (soldered) ribbon cables... so be very careful.
unplug and re-plug the connectors. It that works wonderful.
If you see some remarkable contamination... wring all the juice out of an alcohol swab... wipe it... and take a toothpick point of white lithium only on the metal to protect the surface
(extremely sparsely... the cure can be a problematic as the trouble),
Failing all that... start noting the SPECIFIC CARD NUMBERS to look up on the INTERNET.
Its been a long while ... Most modern sets have three basic components...
1. screen assembly (usu: the “everything else” board is connected directly)
2. Power board (transformers and lots of capacitors... leave it B).
3. “everything else” RF receiver, amps... etc.
4. (I haven't opened a set since the started putting in the 802.11 features
If re-seating works... wonderful (quit while you are ahead)
You are left with writing down the BOARD numbers of those circuit cards... and hunting them up on the internet.
Bunches less than having a SEMI-SKILLED "tech" possibly ruin your set for you... in two trips (minimum).
Good luck and happy hunting
LG 60PG60 60 in.... | Answered on Nov 01, 2015
on the left side, at the back from bottom to top you have,
one yellow connection,
then one white,
then one red
then you have a hdmi connection
and above that its the usb port marked with something like a fork
LG 60PG60 60 in.... | Answered on Aug 28, 2012
I have a Lg 60 pg. It has sound but no picture what could be the possible cause?
LG 60PG60 60 in.... | Answered on Mar 24, 2012
try to visit to this site for more info about plasma TV..
http://www.plasmafix.com/plasma.php
LG 60PG60 60 in.... | Answered on Dec 24, 2011
Usually plasma TV problems start with the screen. If the plasma screen is broken or crashed, it's not repairable any more . It needs a new plasma screen replacement, which may cost you more then the plasma TV itself. ( new screen run ..2 -3k in real life .) Budget management !!! Protection front screen (glass on front) can be easily replaced and not so expensive as PDP panel behind it. If you have just protection screen damage your screen(PDP panel) will work without any problem . Plasma screen contains - aluminum base and two pieces of glass with gas between them ( gas inside not rechargeable ). Pixels with gas , controlled by small electrodes . Each pixel contains 3 colored sub pixels : they are green, blue and red. Plasma screen works in 2 steps:
--- gas ignition
Either there is bulging capacitors on the main power board,or the Y Board lower is faulty. If the entire screen was black I would lean toward the Y Main Board,or if the upper half was black then i would say the Y Buffer upper board is defective.
LG 60PG60 60 in.... | Answered on Nov 01, 2009
I as a technician that repairs LG,Sony,Hitachi,Mitsubishi,Samsung ,etc..Have found that LG is the one brand that I have nothing bad to say about.I love working on their products and they have the best support for technicians compared to all other brands.You as a customer can benifit from this because of the vast knowledge that technicians will have if you were to have a problem.As I stated I work on all brands in warranty and out and LG parts are cheaper than most.On the other hand you may buy another brand only to findout it was made by LG. Philips,Toshiba,are examples of this some of their units are made by LG,And chances are 50% of the Plasmas on the market contain LG made plasma panels.Good luck hope this helps.
LG 60PG60 60 in.... | Answered on Jul 14, 2009
If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Screen-shots to defective LCD and Plasma panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent...
LG Televison &... | Answered on Jul 01, 2020
Did you know there's a "deep detox" you can do first thing in the morning to burn more fat? And the good news is It only takes 13-seconds! Here it is->>:)w­w­w­.­­­w­­­o­­­r­­­k­­­n­­­e­­­t­­8.­c­o­m->>
LG Televison &... | Answered on Jun 29, 2020
It was thrown out for a reason, and probably because it is uneconomical to repair. Take to a repairer for a quotation to fix it.
This explains why, and why you can't diagnose television problems on an online forum. The television sections are really only for help with manuals and remote codes.
Here are similar questions that we see often.
Question:
I've replaced everything in my television because it previously had a black screen with no lighting. Now it doesn't turn on at all and all I have is audio. What could be the cause ? Or
Turns on and sound works fine, but the picture is distorted (solarized? polarized? not sure what the term is) I replaced the main board, but that didn't fix it.
Or
I have an LG 55LM6200-UE with a dim lower-left. I just replaced both LED strips with no resolution. There is no physical obstruction visible, so this has to be a cable or board problem, right?
So your television stops working properly and you think it must be easy to fix, because you can buy boards on eBay, and you can watch YouTube videos. So you make a decision, you buy a board and you fit it, but the television still doesn't work as it should! This is a classic case of the 'let's try replacing this' method of television repair and illustrates why it is a bad idea. It doesn't work for a number of reasons. To correctly diagnose issues, you need to know every board, what it does and every component on the board. You need to know which part has failed, replace the component, or replace the board. The parts you purchased off eBay were probably out of scrapped sets and not tested. The part you put in was dead when you put it in, so you just moved on to another guess at what might be the cause and replace a board that is fine. And so it goes on, you change all the boards and it still doesn't work. Did you notice the large print that says 'NO Refunds, NO Returns'. This is to stop you sending your old one back and saying it didn't work, but the unscrupulous sellers use it as an excuse to get money for selling items that may, or may not work! The course to be a television engineer is 2 years full time education, take it to someone that knows how to diagnose and fix. It is by far the cheapest option. The part that failed might be a 20 cents fuse diode hard soldered to a board. They will charge you $5 in parts and a couple of hours labour. It's not the fix you want to hear, but it is the best advice.
Andrew - Fixya Moderator
LG Televison &... | Answered on Jun 28, 2020
LG 60PG60 60 in. Plasma HDTV Logo
Popular Tags
21 questions posted
Muntejaya Ginting
Muntejaya Ginting
Ekse
View Most Popular
  • LG Televison & Video
Most Popular Question
horizontal lines accross bottom our
  • Televison & Video
