20 Most Recent
Toshiba Satellite L355-S7817 Notebook Questions & Answers
Webcam does not work
just had a look on the toshiba website and there are no win 7 64 bit drivers for your webcam....which is kind of wierd and might explain why your camera doesn't work....there is however a winvista 64 bit driver which might work go here for driverhttp://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2060016&rpn=PSLD0U&modelFilter=L355-S7817&selCategory=2756709&selFamily=1073768663
7/25/2012 6:51:14 PM •
Toshiba...
Answered
on Jul 25, 2012
My toshiba l355-s7187 laptop has an issue starting
Hi
Thank you for your query
The error message indicates that you have corrupted system files
Please try the following
1) Start Laptop
2) Continuously press the F8 key until a startup menu is repsented
3) Choose safe mode from the menu
4) Once safe mode has loaded up click on Start>Programs>Accesories>System Tools>System Restore
5) From system restore choose 'restore my computer to an earlier time'
6) From the calender presented please select a dat in bold lettering back a few weeks before this fault was seen
7) Choose the date and click next..............follow the instructions through
If the system restore fails as above Try the following
1)Put restore CD into drive and restart PC
2) Choose repair from the options and then follow on the on screen instructions
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
2/19/2010 12:59:34 PM •
Toshiba...
Answered
on Feb 19, 2010
The power connection broke and fell inside the
there is a recall for this problem on your model, it requires a new base assembly and dc-in harness. feel free to send it into the repair depot as no other repair facility is authorized to work on your model.
10/30/2009 12:08:29 AM •
Toshiba...
Answered
on Oct 30, 2009
Black Screen Error, Windows Vista Dosenot Boot
You have a complicated issue that is very difficult to repair using this one way conversation method. I must, however, compliment the detail of your description.
From what I can see, you have a problem with one of two, or possibly two of two things. One message says your network card is not functioning properly, the other says your hard drive is not functioning properly.
Either of these issues may be either the device which has failed or the software which controls it has failed.
If you have access to another machine, you may be able to remove the hard drive and test it (this would be my first choice, since a recovery disk should still work even if the Network card does not).
By testing the harddrive, you can be sure it is working properly. If it is working properly, the next test would be on the memory. Believe it or not, memory often will stop a system from reading data off the DVD drive during recovery or installation of the operating system.
This one would be much easier for me to help you diagnose if I had it in my possession, and I'm certain most techs will tell you the same thing.
Additionally, the recovery disk may actually be bad, and this can be investigated with a visual inspection. Look for scratches and fingerprints on the disk.
And often, Windows Vista does not install unless the BIOS is set to the INSTALL OS mode. Different machines do this differently; and again, if you had another machine that was working, it would help.
Good luck.
5/17/2009 6:51:55 PM •
Toshiba...
Answered
on May 17, 2009
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
How can a fix error code oxcoooooof
Just restore your system from a backup taken before the error code started.
If you have no backup then you need to format your hard disk and do a complete reinstall of all your software.
3/19/2020 10:52:50 AM •
Toshiba...
Answered
on Mar 19, 2020
How to play a DVD on Toshiba Satellite Pro C850
If you know the DVD and the DVD drive is in proper working order, it could mean that the software you are running just may have some problems. Try downloading a copy of VLC (VideoLan Client) this application is free and open source (and no it's not something I created and am just trying to get people to use...it's just something that works great, and completely free) VLC can play almost any video file or DVD that it encounters. If VLC can't play it, I would think it's likely there may be something with your disk or your DVD drive.
3/11/2020 8:58:46 AM •
Toshiba...
Answered
on Mar 11, 2020
