20 Most Recent Lenovo ThinkPad T61 6457 Notebook Questions & Answers
Lenevo t61 1 long beep and 2 short beeo
Standard Original IBM POST Error Codes 1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
11/9/2012 1:11:02 AM • Lenovo ThinkPad... • Answered on Nov 09, 2012
Display graphics
Try updating your graphics drivers
7/1/2011 4:11:02 PM • Lenovo ThinkPad... • Answered on Jul 01, 2011
I have a Lenovo T61 with intel GM655 graphics.
I think you can try to download the video graphics driver from lenovo website.
4/22/2011 4:50:30 AM • Lenovo ThinkPad... • Answered on Apr 22, 2011
On start up my touch
Does this happen with an external mouse too?
If no, then reinstall the touchpad drivers.
If yes, then chances are your laptop is suffering from a poor contact/cold solder on the FSB chip. If this is the case, the only solution is a new motherboard or a reflow of the FSB chip. If the FSB chip has a dry solder, joint then you should be experiencing some other problems too: slow DVD reading, keyboard freezes sometimes, problem with USB ports etc. Next time this happens, twist the laptop as you'd twist a book. This should add some tension between the motherboard and FSB and hopefully restore contact. Note that this is not a permanent solution, but a diagnostic step to see if it's really a FSB issue.
1/2/2011 10:04:44 AM • Lenovo ThinkPad... • Answered on Jan 02, 2011
SL500 does nothing when power
remove the battery large. then run on AC pack only #1 top failure of all mobile PC is that battery, so unplug it then test with AC pack only. work now.? and all vents must be clean, end to end. not just fan. there i no fuse it uses current regulator, imagine genius magic electronics fuses that never blow out, and bingo. OK big battery out, an RTC coin cell fresh. then fan blows. next is BIOS, do the BIOS screens work if not the mobo is dead. have 2 RAM stick on the 2 slots>? try one at a time run the PC with all modules removed, (options) remove hdd? remove, dvd drive. think like this. Get bios working first learn that modules can short, and when they do the power regs shut down. so we unplug all things to the mob, until only 1 ram and cpu remains. see? (this is called power overload fault isolation tactics) even the screen only can be dead, you never mention text showing you can test the mobo with external screen via that rear (?)_ VGA jack what if that worked, did you learn something here, sure. this pc has tons of modules to pull, even bluetooth. wifi, sound and more. if you look at all parts inside or sold by ebay, bingo. lots
8/14/2018 12:52:53 PM • Lenovo ThinkPad... • Answered on Aug 14, 2018
2answers
Screen lock
It helps to know what device model and OS you are using though the following steps for changing from pattern lock to slide are for Android OS 4.0 (Ice Cream Sandwich):1. Unlock your Android device2. Find the Applications menu and select "Settings"3. Under the "PERSONAL" group, select " Security"4. Under "SCREEN SECURITY" group, select "Screen Lock"This will ask for the security pattern first.5. The options for screen lock will appear, select "Slide" and you are done!Hope this helps.
3/14/2017 5:21:09 AM • Lenovo ThinkPad... • Answered on Mar 14, 2017
How can I activate the camera?
2/16/2016 4:15:32 PM • Lenovo ThinkPad... • Answered on Feb 16, 2016
G500 how reach bios setting
Just press "delete" "F2" or "Escape" keys imediately then you power on your computer. (Key depends on your pc model)
1/8/2016 7:24:01 PM • Lenovo ThinkPad... • Answered on Jan 08, 2016
HOW RESET BIOS PASSWORD TOSHIBA M11
Try this http://www.wikihow.com/Clear-BIOS-Password
1/8/2016 7:18:55 PM • Lenovo ThinkPad... • Answered on Jan 08, 2016
My pointer in my touchpad wont move it will move with my pointer
Do you mean it will move with a mouse, but not the touchpad? If so, maybe settings in this article will help: https://support.lenovo.com/us/en/documents/ht075745
11/26/2015 4:46:51 AM • Lenovo ThinkPad... • Answered on Nov 26, 2015
Lenovo ThinkPad T61 6457 Notebook Logo
Popular Tags
9 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad Lenovo
  • ThinkPad Lenovo
Most Popular Question
lenovo t61 intel gm655 graphics
  • Computers & Internet
