20 Most Recent Coby MP-C653 MP3 Player Questions & Answers
You can download the manual from the manufacturer's web site at
http://www.cobyusa.com/files/manuals/MP620_MN.pdf
Coby MP-C653 ... | Answered on Aug 03, 2010
Normal audio CD tracks should be converted to mp3 files onto the computer's hard drive, first.
This is called ripping or RIP function.
There are several programs that can RIP audio CD.
It is important to convert music into the correct bitrate for the player to match for playback. (192 kbps is good quality and often used)
You can use Windows Media Player 10 or 11 for conversion.
When you use WMP 10 or 11 and the player is detected in the program:
1. Tell the player were your music library is: setup your music library.
2. Create a playlist; make playlist name and add mp3 files to the list.
3. Synchronize the playlist with mp3 files to the player.
If the player cannot be detected in WMP 10 or 11, but only can be viewed as a removable disk in "My Computer" : use the "copy and paste" or "drag and drop" method to put mp3 files from the computer onto the player.
When needing more help, don't hesitate to write a comment in this reply.
Coby MP-C653 ... | Answered on May 01, 2010
create a folder and rename it as the name of the artist you want, then transfer all the artist songs into that folder in your mp3 this should be done with your computer
Coby MP-C653 ... | Answered on Feb 20, 2010
You can open windows media player and tranfer music from your computer to your mp3 player. If that does not work go to "my computer" and open your mp3 player and locate the music folder and drag and drop your music.
Coby MP-C653 ... | Answered on Sep 24, 2009
Hi stetsoncowgi...
Downloading Music to MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Please take time to rate me
Coby Audio... | Answered on Apr 21, 2020
Ever use ANY blu tooth apps? I would suggest either learning how to. Or updating your device.
Coby Audio... | Answered on Dec 26, 2019
Step 1 Select locations for each of the Coby 5.1 speakers. Place the correct channel speakers in the best location possible. For example, a right-rear speaker should not be placed to the front left of the TV.
Step 2 Measure and cut lengths of speaker wire that run from each speaker to the Coby receiver. Include a few extra feet for mistakes. The speaker wire has two color wires, a red (power) and black (ground).
Step 3 Attach the red wire to the positive (+) terminal for each speaker. Attach the black wire to the ground (-) of each speaker.
Step 4 Make sure the receiver is unplugged. Examine the back of the receiver. There are speaker terminals for each of the speakers. Plug each speaker wire into its respective terminal. For example, plug the right-rear speaker into the right-rear terminal. Each terminal is clearly labeled.
Plug RCA cables into the appropriate input ports on the receiver. For example, there are RCA ports for the TV and DVD player. Plug the other ends of the RCA cables into their appropriate devices. For example, the DVD input on the receiver plugs into the audio output port on the DVD player. RCA audio cables are red and white, make sure to match the colors correctly: red with red, white with white.
Items you will need
  • Speaker wire
  • Wire stripper
  • RCA cables
Coby Audio... | Answered on Apr 06, 2019
Coby MP-C653  MP3 Player Logo
8 questions posted
Top Coby Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Coby Audio Players & Recorders
Most Popular Question
download songs from home computer
  • Audio Players & Recorders
