20 Most Recent Compaq Hewlett Packard Presario SR5110NX PC Desktop Questions & Answers
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c01050244#N232 Is the link to find your answer. And in case you get lost.....
Compaq Hewlett... | Answered on Sep 03, 2014
FROM WHERE YOU HAVE TO BE MOORE DETAILED.
Compaq Hewlett... | Answered on Aug 03, 2014
Some fans will not engage if the case is open, others need to be activated in bios (set temp). Also check if the wires are reversed. Some have a diode that only works with current in one direction. Very few use an ac current.
Compaq Hewlett... | Answered on Dec 17, 2013
Hello Friend,
Some PC also noise like, SMPS fan, CPU fan, external cabinet connect fan. If this types of noise create then you clean all fan dust i think problem solved. You know CUP also create noise it`s default so not any solution.
Compaq Hewlett... | Answered on Aug 22, 2013
Change your sleep settings in the Control Panel under Power Options. You can set it to never go to sleep or have it to go to sleep after 2 hours. There will be settings to control when the monitor shuts off, when the hard drive shuts off, etc.
Compaq Hewlett... | Answered on Apr 24, 2012
clear all 3rd party startup items you dont need with msconfig.exe. Uninstall bellaliant and use microsoft security essentials as main antivirus software and defragment your hard drive.
Compaq Hewlett... | Answered on Dec 12, 2011
Boot in safe mode
Start msconfig.exe and configure windows to start with a clean boot.
a. Log on to the computer by using an account that has administrator rights.
b. Click Start, type msconfig.exe in the Start Search box, and then press ENTER to start the System Configuration Utility.
If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
c. On the General tab, click Selective Startup, and then click to clear the Load startup items check box. (The Use Original Boot.ini check box is unavailable.)
d. On the Services tab, click to select the Hide all Microsoft services check box, and then click Disable all.
Note Following this step lets Microsoft services continue to run. These services include Networking, Plug and Play, Event Logging, Error Reporting, and other services. If you disable these services, you may permanently delete all restore points. Do not do this if you want to use the System Restore utility together with existing restore points.
e. Click OK, and then click Restart.
Boot the machine in normal mode.
Compaq Hewlett... | Answered on Dec 08, 2011
It has to have the pin hole safety. It is required by IEEE standards. make sure you check the entire face of the CD drive for it. It can be mistaken for light or appear along the tray's edge (making it really hard to see), but I promise it has to be there.
Compaq Hewlett... | Answered on May 14, 2011
you can purchase a power supply from any computer store *********** board supports both standard IDE and Serial ATA connections, so you want a power supply that does SATA power as well. Unplug the power cord from the back of the computer. remove the cover from the case and verify that there is no green LED on the board that is lit up (if there is, there is still power on the board). unplug all connections from the current power supply, including all drive power and the large 24pin plug (actually a 4 pin plug that is combined with a 20 pin plug) on the board, then unplug the 4 pin plug near the processor. careful that the 24 pin plug and the additional 4 pin plug near the processor have latches on the side. Remove the 4 screws that hold the power supply in and remove the power supply, install new supply and reinstall the 4 screws. first plug in the 4 pin plug that connects with the 20 pin, the 4 pin plug has no latch, it is held in place by the 20 pin plug. then plug in the 20 pin plug and the 4 pin next to the processor. then plug in the drive power to all of the drives. Install the power plug at the back of the system and you should see a green LED on the board when you insert the power. replace the cover and power the system up.
Compaq Hewlett... | Answered on Apr 03, 2010
just download imgburn which is a free software to burn dvd's etc. Google "imgburn" and follow the appropriate links to download. Its easy to use by the way.
Compaq Hewlett... | Answered on May 29, 2009
Depending upon where you live in the world, this may be perfectly legal...
On the other hand, you might have no recourse, but to buy another copy.
Might I suggest ebay ?
Compaq Computers... | Answered on Jun 29, 2020
Install KMP or VLC for Play the Video it will Work
Compaq Computers... | Answered on May 29, 2020
Good luck with that. Why would you want a 23 year old CRT when there are Ultra HD flat widescreen monitors available. Even if you could find on in working order, it is likely to fail in the very near future.
Compaq Computers... | Answered on Apr 30, 2020
Try downloading VLC media player. Do a quick Google search for it.
VLC is a free media player and without additional downloads will play almost any format you can throw at it.
Compaq Computers... | Answered on Mar 24, 2020
Try installing VLC (VideoLAN- you can get it free by googling it) and using it to open the disk. Should work fine
Compaq Computers... | Answered on Mar 10, 2020
use wired Ethernet, so it works. easy.
wifi is far more complex.
best is to own the router, you have.
then login to it and set it up for wpa./wpa2
wep off.
and a nice password for wifi so others cant hack it. in the hood.
then use those credentials all all your toys. xbox, PCs and cell.
that is the best way
the access point is covered in you manual for the router
there is AP button there, you push.
the PC in question my guess is the drivers are no good.
missing wrong, or corrupted.
no PC full model stated.
no OS stated
no router stated.
so answers will be weak to wrong,.
Compaq Computers... | Answered on Jan 20, 2020
Compaq Hewlett Packard Presario SR5110NX  PC Desktop Logo
13 questions posted
Top Compaq Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
cd drive jammed
  • Computers & Internet
