20 Most Recent Kodak EASYSHARE V1253 Digital Camera Questions & Answers
This might be the camera's internal computer going bad. Check with customer service. Even if your warranty is not valid, they might be still either fix your camera or refer you to one of their local service centers. Hope this helps. Mike
Kodak EASYSHARE... | Answered on Dec 13, 2015
Hello
Actually there is a sensor responsible to tell the camera that the lens is out and ready to be used. And if the said sensor does not trip then the camera thinks that there is a prob. Try the following
1. Turn on the camera
2. Notice the movement of the lens as to which direction is it Turing while it is getting ready
3. try to pull the leans assy. a little outwords. But be gentle. Once the sensor has detected by the camera it will remain ON
Kodak EASYSHARE... | Answered on Apr 21, 2015
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Kodak EASYSHARE... | Answered on Apr 16, 2014
Maybe the lens movement is sticking and causing additional overload for the camera circuits, thus causing it to shut down.
Kodak EASYSHARE... | Answered on Dec 21, 2013
You might need new batteries, or the LCD panel might need to be replaced. The panels are available for 20-30USD
Kodak EASYSHARE... | Answered on Mar 27, 2013
Check all the settings under menu / setup. Try a firmware update from Kodak support page, if no change camera will need service.
Kodak EASYSHARE... | Answered on Jan 27, 2013
Nothing new for this model Kodak, Tons of problems with these. Good luck.
Kodak EASYSHARE... | Answered on Jan 24, 2013
This is a motor drive problem, it requires repairs soon as possible before any more damage is done.
Hello Tom, This is normally a sign of internal problems. you could try a different battery but I don't think that is the cure.
Best Regards, Russell
You don't need any special software in order to use your camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Kodak EASYSHARE... | Answered on Jan 17, 2013
what is the solution for this problem of red blurred pictures
Kodak EASYSHARE... | Answered on Dec 30, 2012
An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to arrange your repair/Trade up: Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
I'll suggest you should try to upload new firmware:
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=11650/11659&product=EKN033562
Kodak EASYSHARE... | Answered on Aug 25, 2012
These parts could be difficult enough to obtain. You will need to put in a special order as these will not be carried in normal stock.
I have used these guys before for special orders. Try this email and hopefully you might just get a result
[email protected]
Hope this helps.
Please check the news battery originality .
Kodak EASYSHARE... | Answered on Aug 08, 2012
Kodak EASYSHARE V1253 Digital Camera Logo
109 questions posted
Top Kodak Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
v1253 camera software download
  • Cameras
