20 Most Recent
GoPro Digital Hero 3 Digital Camera Questions & Answers
My goPro hero HD is
Find a solution, you can have a try:
1. SD Card out
2. Battery out wait 10 seconds
3. Battery in wait 1 minute (this extra time was the key to getting this sequence to work for me)
4. Power up take a photo, power down (you have about a three second window before it goes into Tel mode)
5. Wait 1 min
6. Power up (NB still no SD card)
At this point camera appears to be working stays in normal mode with --- displayed because no SD card is inserted.
Also interestingly plugging a video output cable into HDTV output socket makes camera go to Tel mode AND when you unplug it camera goes back to normal.
However plugging the SD card sends camera into Tel mode permanently. On the plus side this 1-6 sequence was repeatable and worked every time.
From this point I tried many combination's of video cables, SD cards, formatted, erased waiting....then came the USB cable!
7. Connect USB cable to computer (NB still no SD card installed)
8. Insert SD (Computer should detect card and any photos taken should be viewable)
9. "Eject" Camera from Computer USB
10. Disconnect camera from USB (should power down by itself)
11. Power up Camera, Woohoo! it works again!
BTW, if you don't know how to connect GoPro to TV, you guys can check the following guide for help.
Guide:
How to Connect GoPro to TV
Connecting to ipad
No direct connection possible right now. Perhaps in the future?
To get your video on the iPad you could use a memory card reader, or a wifi memory card. But both are not capable to stream video streams life.
Perhaps Apple, can be moved to bring a connection tool, for video, but there is noting right now.
How to reset gopro hero3?
We've found the best way is to remove the SD card and the batteries for at least 30 seconds and then reinstall both and turn the camera on. Remember, that in addition to the data saved on the SD card, by plugging your camera into your PC with the USB cable you will be able to find any images or video stored on the camera's built in memory.
We've put together a
tip sheet for the GoPro Hero 5 cameras but much of the information will help you get the most out of your Hero 3. It is important that you do not attempt to update a Hero 3 using the available
GoPro firmware update as it is ONLY for wide angle Hero 5 cameras.
If we can answer any other GoPro support questions feel free to visit us at
IcePlanter.com or contact GoPro directly.
I need to mount the
Ugrade your camera to the latest firmware (file and instructions available on their website). Once you've done this you'll be able to set the camera in the menu to record the video upside down. This enables upside down mounting and your video will be the right way up.
