20 Most Recent Fuji J150w Digital Camera Questions & Answers
Uploading pictures from camera to pc get run time error
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
11/19/2014 12:28:15 AM • Fuji J150w... • Answered on Nov 19, 2014
I keep getting a zoom error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
11/9/2010 4:06:09 PM • Fuji J150w... • Answered on Nov 09, 2010
I have fuji camara j150w . i deleted the whole
Hello
My apologies if this message finds you long after posting this problem , but I am currently working through a backlog of problems that never got answered and hopefully this info can still be of use if not now possibly in future.
Please download Disc Digger HERE. This is a free tool you can use that works very well and there is no installation required, just run the program once you downloaded it.
Once you have connected the memory card to the computer via either the camera or preferably with a usb card reader , run the program.
On the program , select the dig deep option for accidentaly deleted files or dig deeper for a formatted card. Then select the card you want to do the recovery on and run the program.
The data will be displayed and you can recover it from there. This will only work if the card has not been used since the pictures were lost. Save the files to a location on the computer hard drive and not back to the memory card as this will overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
9/29/2010 2:11:56 PM • Fuji J150w... • Answered on Sep 29, 2010
Blank screen, intermittant. still takes pictures.
It's under warranty still (just!) and is faulty.
Don't waste time trying to fix this, just claim on the warranty before it's too late.
3/18/2010 5:30:53 PM • Fuji J150w... • Answered on Mar 18, 2010
My fujifilm finepix camera gets stuck when i look
The card is probably defective.
But before buying a new card, try to format the card in the camera. Make sure you have saved all images first. Formatting will "reset" the card and delete all images.
To format the card: Menu/ok, Setup, Format, OK
2/19/2010 12:25:37 PM • Fuji J150w... • Answered on Feb 19, 2010
Trying to download the instruction booklet that
You can download the required manual by clicking this link:
http://fujifilm.co.uk/media/dContent/119539/productFilesManualsFile.pdf
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks.
11/9/2009 4:17:45 PM • Fuji J150w... • Answered on Nov 09, 2009
The
You can try to set all the menus to default, but this camera may need repair.
Make sure you have the right kind of batteries.
Putting in the wrong kind of batteries may cause errors.
10/19/2009 5:52:10 PM • Fuji J150w... • Answered on Oct 19, 2009
Hi my Finepix j150w won't let me download photos -
try update the software viewer with ver. 5.05
9/20/2009 4:51:12 AM • Fuji J150w... • Answered on Sep 20, 2009
Transfer photos from internal memory
get the USB cable that came with the packaging of this camera, connect the small end to your camera the other to the computer, then let it sit there for a minute or two until drivers are running. once done go to My Computer and you should be able to see the camera as a mass storage device, opening it will show you the pictures.
right there you can make a copy and paste to anywhere in your machine
9/11/2009 1:19:03 AM • Fuji J150w... • Answered on Sep 11, 2009
My shutter will not open. The power button presses
Can you get any signs of life? playback pictures etc? Try pressing the playback button instead of the power button. If camera display works then press the picture button and see if the camera will switch over and the lens extends. Also check if the tab on the battery door is not broken. This operates a micro switch to cut off power
6/20/2009 7:23:15 AM • Fuji J150w... • Answered on Jun 20, 2009
Yellowish line on LCD, pics, and video. Digital zoom gets rid of this problem, but isn't acceptable.
Fuji is Good in warranty dont worry
ur problem might be small as some dirt inside the lens or
might be big as CCD Fault but very rare in this model
kindly call Fuji for the repair FREE offcourse they are a good company and very good at customer support
Pls rate me WELL !
5/23/2009 9:27:27 PM • Fuji J150w... • Answered on May 23, 2009
My son pulled out one of the shutters that opens
You can pull off the other one if you want. To put it back in your basically going to have to take apart the camera. The "Shutters" on the outside is nothing more but to protect the lens will its in the camera. The actual shutter is inside the lens that open and closes very quickly when you take a picture.
Think of it this way, the shutter in the lens opens up to let in light that shows the image to the sensor behind the lens. Then it closes to "finish" capturing the light".
The "shutters" or "doors" on the outside do not move once you take a picture. They only close once the lens retract. (When the camera is turned off or idles)
Hope this has been helpful.
3/30/2009 1:56:18 PM • Fuji J150w... • Answered on Mar 30, 2009
Fujifilm finepix j150w has slow shutter speed
Most digital compact cameras suffer from this shutter lag, though some cameras have managed to reduce it considerably. This is normal.
2/14/2009 9:33:13 AM • Fuji J150w... • Answered on Feb 14, 2009
ERROR E-2415, 2416, 2418, 2411 FOR FUJI FRONTIER 370 WHAT IS THE ERROR PLEASE REPLY ME
The answer is still the same
7/4/2020 12:01:10 PM • Fuji Cameras • Answered on Jul 04, 2020
Focus error
hi i need help with my focus errar
6/21/2020 2:39:51 PM • Fuji Cameras • Answered on Jun 21, 2020
Fuji 370 Error Message W-2649
Sounds interesting - what does it mean ?
12/24/2019 5:31:20 PM • Fuji Cameras • Answered on Dec 24, 2019
How do I turn off the date stamp on a Fuji XP?
Follow the "instructions" in the "manual"
9/19/2019 7:58:14 PM • Fuji Cameras • Answered on Sep 19, 2019
Fuji J150w Digital Camera Logo
Popular Tags
19 questions posted
Top Fuji Cameras Experts
Steven Wander
Steven Wander
David Shaub
Steve
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
Fuji Cameras
  • Fuji Cameras
Most Popular Question
fuji camara j150w deleted whole
  • Cameras
