20 Most Recent Canon EOS 450D Digital Camera Questions & Answers
Canon 450D - Error 99 only when flash pops up
Flash Tube is bad inside the Flah head, tccamerarepair.com
2/1/2018 3:40:15 PM • Canon EOS 450D ... • Answered on Feb 01, 2018
AF not working properly
Please give more details about camera & lens make type so that solution can be given.
1/12/2018 7:09:31 AM • Canon EOS 450D ... • Answered on Jan 12, 2018
How do I adjust the grid horizon line please? Every shot when aligned with this, is off horizontal. Thanks
Have you considered getting a hot-shoe mounted spirit level ? They ensure that the camera is completely level, with no possibility of adjustment error. Should be available on Ebay.
5/2/2016 11:51:12 AM • Canon EOS 450D ... • Answered on May 02, 2016
Reset factory settings
There's a setting in the menu selection that usually reads "Reset to Factory Settings" or something similar. You can find a PDF manual on Canon's website.
12/10/2015 5:43:41 AM • Canon EOS 450D ... • Answered on Dec 10, 2015
Water damage
If the problem is water in your camera a good way to remove it is to place the camera into a pack of rice. The rice will absorb the water.
5/12/2015 6:47:56 PM • Canon EOS 450D ... • Answered on May 12, 2015
Not compatible with acer laptop windows 8.1
The statement is not complete, because you forgot to say what is not compatible. When you think the Canon EOS 450D is not you are wrong. For most operating systems you can download the software needed to connect the Canon cameras and acces their memory. You don't need a driver for Windows 8 just install Zoom browser Search Results
3/17/2015 12:22:05 PM • Canon EOS 450D ... • Answered on Mar 17, 2015
When selecting AEB & Flash exp comp,I have lost
Canon Support Drivers EOS 5D Mark II You can download any camera manual directly from Canon's website.
8/14/2014 12:26:53 PM • Canon EOS 450D ... • Answered on Aug 14, 2014
What is the latest firmware for canon 450d?
1.1.0 and this site from Canon, you can download the firmware. Canon EOS REBEL XSi 450D Firmware Download Only when you have a new lens, not yet supported by your came, I would get the firmware.
7/27/2014 8:21:43 PM • Canon EOS 450D ... • Answered on Jul 27, 2014
0answers
Reset
Be the first to answer 3/25/2014 6:15:17 AM • Canon EOS 450D ... • Posted on Mar 25, 2014Be the first to answer
Auto Focus won't work
Another cause of auto focus failure is the circuit connecting the moving parts inside the lens. These "Flexi circuits" move with the lens components and wear out after a while. They are cheap enough to find on ebay and easy to replace.
1/2/2014 4:11:16 PM • Canon EOS 450D ... • Answered on Jan 02, 2014
How can i remove the write protect in my SD card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
11/28/2013 3:13:34 AM • Canon EOS 450D ... • Answered on Nov 28, 2013
Canon 450d lcd will not turn on at all, viewfinder says busy, and camera will not take pictures
In menu option C.Fn-12 you can choose to switch the display off (or on) when you switch on the camera. The display stays off even if you switch of and on the camera. Press the button <DISP> and switch off the camera, while the settings for recording are on the screen. After you switch on the camera, the LCD screen will be switched on again. Please refer toy your english manual, I had to translate, because I don't have the English version.
11/20/2013 4:30:20 PM • Canon EOS 450D ... • Answered on Nov 20, 2013
Error code 001 with canon 450d
Seems a lot of people are having the same problem. Take the lens off the camera and clean the little gold contacts (metal squares) on both the lens and the body with isopropyl alcohol or pre-moistened len wipes.
10/25/2013 5:56:46 AM • Canon EOS 450D ... • Answered on Oct 25, 2013
The battery is fully charged.but when i come to
bad main circuit is most probably cause
8/6/2013 2:56:58 AM • Canon EOS 450D ... • Answered on Aug 06, 2013
Canon EOS 450D  Digital Camera Logo
134 questions posted
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Eos Canon
  • Eos Canon
Most Popular Question
battery fully charged but when come
  • Cameras
