20 Most Recent LG WM2277HSW XL Front Load Stackable Washing Machine Questions & Answers
2answers
What is the issue with LG washer
LG WM2277HSW XL Front Load... Repair Questions - Fixya
www.fixya.com/.../p95436-lg_wm2277hsw_xl_front_load_stackable
Recent LG WM2277HSW XL Front Load Stackable Washing Machine questions, problems & answers. ... My frontloader washmachine will not turn on ยท LG ...
LG WM2277HSW XL Front Load Stackable Washing ... - Fixya
www.fixya.com/search/p95436-lg_wm2277hsw_xl_front_load.../open
LG WM2277HSW XL Front Load Stackable Washing Machine, open related issues. Get free ... Wait 5 secs after turning off door release should open. If this does not ... OE error message won't open door, won't spin out water What is filters & open it are my problemsDue to that I cann't ... Where is it sticking and how do I fix it?
LG Tromm WD 12270 RD washer and dryer 'LG ...
1/10/2016 5:11:08 AM • LG WM2277HSW XL... • Answered on Jan 10, 2016
0answers
Check mains supply lead and also the in-line fuse for condition. The main control board could also be faulty.
3/29/2014 9:13:59 AM • LG WM2277HSW XL... • Answered on Mar 29, 2014
WM2277HS front loader , the drawer to put the
I have slightly different model. Tried the remove the top option. It turned out the the drawer assembly had removable top, removed to two screws that held the assembly in place, uncliped e front assymply drawer handle and cleaned out the soap deposits. Soap build up under dispenser parts had caused the problem. It seems like running the machine a few times might have cleared the soap.
7/29/2012 7:42:37 PM • LG WM2277HSW XL... • Answered on Jul 29, 2012
2answers
I have a WM2277HS TROMM Washing Machine and at the
Sounds like a bad lid switch. Check to see if you hear a "click" from the switch when you open and close the lid. If you do not, then you should replace the lid switch.
11/26/2010 2:48:38 PM • LG WM2277HSW XL... • Answered on Nov 26, 2010
What does LE in my wachine machine WM2277HS mean?
LE indicates a fault with the motor on the appliance.
LG suggest you switch off, wait for a minute, unplug the appliance.
Wait 15 minutes then plug it back in again.
Try the machine again.
If it's still faulty, you can try changing the Hall Sensor in the motor, this can sometimes cure the problem.
Unplug the machine and remove the rear cover. There are 4 Philips head screws. Take them out and remove the rear cover.
You should now see the rear of the motor, which is mounted to the back of the drum.
In the middle is a large bolt which holds the stator cover.
You'll need a 17mm socket and a ratchet to remove this bolt.
Remove the stator cover and place aside.
Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
Through the motor there are 6 bolts holding it onto the back of the drum assembly.
You'll need a 10mm socket and ratchet to remove them.
You will now have the motor off the back of the drum.
Disconnect the two wire harnesses from the motor.
Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small pieces clipped onto it, toward the bottom.
The sensor you are looking to replace is the one that looks like a kitchen magnet.
It is attached by small clips. You'll see how it goes on. It's easy to remove.
Go to google and search for part number 6501KW2002A.
This will bring up an LG sensor assembly.
Double check with the supplier that this is the sensor for your appliance.
When you receive the sensor, simply reverse steps 1 through 5.
Once re assembled, try the machine again.
If still the same after this you'll need to replace the motor and/or control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
9/11/2010 10:04:55 PM • LG WM2277HSW XL... • Answered on Sep 11, 2010
Hi, I don't know how to fix your problem, Lia, unfortunately, BUT wanted to say "Thank You!!" for mentioning that you can get the washer to run through the cycle by rotating the drum and switching to cold water wash! We'd tried unplugging, leaving it unplugged overnight even, but the code/beeping started immediately after plugging back in. I'm kind of longing for an old-school washer right now, thinking of all the things that can go wrong with the newer digital-age computerized ones :-) If you see this, please share what you did to solve your washer problem! Hoping it's not too expensive to fix...or I should say to GET it fixed :-\
6/8/2010 3:32:20 PM • LG WM2277HSW XL... • Answered on Jun 08, 2010
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
3/3/2009 1:14:29 PM • LG WM2277HSW XL... • Answered on Mar 03, 2009
Washer
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
please do not forget to rate and comment about your experience with fixya today.
8/18/2008 1:13:20 PM • LG WM2277HSW XL... • Answered on Aug 18, 2008
Lg wm2277hs
Symptom Error Codes
Answer
8/18/2008 3:40:55 AM • LG WM2277HSW XL... • Answered on Aug 18, 2008
Odor in Washer
You're probably using too much soap and softner and it's building up inside the tub. Run the hotest wash you have without any clothes in the unit and add a little bleach. If you see bubbles in the water when it's running that's excess soap you're washing out. Do it over and over until the water stays clear and then start using less soap. It only needs about a tablespoon for a full load.
12/20/2007 5:44:00 PM • LG WM2277HSW XL... • Answered on Dec 20, 2007
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
11/20/2022 7:26:11 PM • LG WM Washing... • Answered on Nov 20, 2022
2answers
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
10/29/2018 1:31:58 PM • LG WM Washing... • Answered on Oct 29, 2018
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
12/27/2017 6:08:54 PM • LG WM Washing... • Answered on Dec 27, 2017
Indesit WM12X the wash program starts then freezes (The dial doesn't turn)
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
4/25/2017 4:31:21 AM • LG WM Washing... • Answered on Apr 25, 2017
LG washing machine Model No: WTH9556 manual
http://www.lg.com/au/support/support-product/lg-WT-H9556
3/29/2017 4:12:09 AM • LG WM Washing... • Answered on Mar 29, 2017
Washing Machines Logo
19 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
wm2277hs tromm washing machine
  • Washing Machines
