20 Most Recent Kohler K-T10335-4-CP Lyntier Rite-temp bath and shower faucet with lever .... Questions & Answers
Probably some pipe rust clogged the exit.
If u have pretty low pressure on one or both, hot and cold water, try keep force closed by hand the water exit at shower pipe, then start both cold and warm water gradually as much as u can keep it closed with the hand.
The pressure of the water will try "escape thru the clogged pipe and hopefully unlock that debris or rust!
The hot water pressure going back thru the cold water pipe might unclog that debris.
Just a simple fix which many times works as a charm..
Otherwise if this is not fixing, try close both water from main service valve.
Then unscrew the secondary shower valves and manually clean them or replace if very damaged.
Kohler... | Answered on Dec 16, 2017
Check that it's hooked up correctly. I've seen this exact problem when the hot water is hooked to the cold side of the valve.
Kohler... | Answered on Oct 17, 2014
replace the cartridge and you will be fine. yo can fine them at most large store that sell plumbing supplys.
They cost about 50.00 not hard to change out
Thanks
Tom
Kohler... | Answered on Sep 16, 2011
They have a anti-scald device on valve.remove handle there is a little white ring with teeth on it and a square stop that stops handle so that you don't get to much hot water,just pull out a little and rotate ring counter clockwise(I think it's been a while since I adjusted one).You may have to play with it a few times but it allows handle to travel further to hot side,allowing more hot water.
Kohler... | Answered on Jun 13, 2011
If the water is only cool in the shower, it could be the shower valve. However if water is cool at all taps, something is not working on the water heater system.
Gary
Kohler... | Answered on Dec 18, 2010
mite have intergral stops behind escution plate (the big round cover plate with 2 screws) that needs to be turned to the on position..
Kohler... | Answered on Nov 25, 2010
You need to order seals and replace them. Typically, dirt in the water system damages the rubber (neoprene, plastic) soft parts. Sometimes the damage wrecks metal parts, but this is less common.
Kohler... | Answered on Oct 05, 2010
Call toll-free 1-800-456-4537
Kohler... | Answered on Sep 14, 2010
Your filters may be blocked on the mixer or it may need replacing
Kohler... | Answered on Jul 04, 2010
Take handle back off and see if it has a dial that can be removed and repostioned. take off and move it about 1/4 turn counter clockwise and reinstalled and try to see if mixture is correct.
Kohler... | Answered on May 18, 2010
If this is a new installation and has always beenj this way, then I would suspect that there may be an obstruction in the cold water line leading to the valve. Or something stuck in the valve at the point where the cold water is connected. If someone has worked on thius valve recently , then I would suspect that they got the valve cartridge in backwards, If the catridge is not placed in the valve correctly the opperation is messed up.
Kohler... | Answered on May 06, 2010
u hve to adjust the temprture ring i think u put it all the way so u lock it ,
Kohler... | Answered on Dec 27, 2009
this is due to the high water pressure !reduce the pressure on your valve
Kohler... | Answered on Nov 16, 2009
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Kohler... | Answered on Oct 24, 2009
Kohler K-T10335-4-CP Lyntier Rite-temp bath and shower faucet with lever .... Logo
32 questions posted
Top Kohler Plumbing Experts
Mike
Bill Johnson
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Kohler Plumbing
  • Kohler Plumbing
Most Popular Question
no hot water in shower
  • Plumbing
