20 Most Recent Jacuzzi Signa 6 Whirlpool JAC-B540... Questions & Answers
possibly some seals deteriorating.. check pump and connections..
Jacuzzi Signa 6... | Answered on Aug 02, 2010
A flashing “FL1” display means the flow switch is
malfunctioning open, the filter cartridge is excessively
dirty or an “air lock” condition has occurred at the
circulation pump intake.
Jacuzzi Signa 6... | Answered on Apr 14, 2010
they work on a air switch the hose might not be hooked up on one end
Jacuzzi Signa 6... | Answered on Feb 15, 2010
If there is room most definitely you can place the faucets on the tub itself. You can mount them on the left rear. However be very careful drilling the holes and make sure you have it aligned correctly before drilling. Check underneath to make sure there is enough room for clearance and hook up. Here is what it will look like. a1da3ad.png
Jacuzzi Signa 6... | Answered on Jan 08, 2010
You are on the right track. Be sure and chlorinate and run the jets at the same time I would let it set for at least a couple of hours running the jet intermittantly and then drain and repeat.
Sound like you have Iron Bacteria. You may want ot contact a water profeessional who can recommend ways of getting rid of the iron.
Properly Chlorinating your well would be a good first step.
What part of the country are you in>
sanray
Jacuzzi Signa 6... | Answered on Apr 11, 2009
Sounds like the hoses to the jets are the pump are breaking down and pieces coming off. Replace the bad hoze(s).
Jacuzzi Signa 6... | Answered on Feb 13, 2009
hi there. FIrst of all be sure the water lever is above all of the jets for it to work properly. REgarding the jet where the water does not come out properly i am not sure what that means. BUT, the jet is adjustable so turn it and see if that fixes the problem. good luck.
Jacuzzi Signa 6... | Answered on Jan 26, 2009
Many time leaks around pumps are a simple o-ring that needs to be cleaned and/or tightened. If the jets are leaking from the back side then the jet will have to be removed and resealed.
Good Luck, Phil
Jacuzzi Signa 6... | Answered on Dec 11, 2008
Several things can cause this problem- if you post a picture of the inside of the tank so we can have a good look at how the fill/stop mechanism operates that would be great. We could more than likely identify some type of problem and solution. Not all flush/fill mechanisms are not the same but thats surely where your problem is UNLESS its in your water lines. I would love to help you just please provide photos and as much information as you can.
Mr.Mike
Jacuzzi Home | Answered on May 20, 2020
Contact the Dealer and seek qualified tech service. Risk of electric shock/***** You should not take the risk but have a QUALIFIED SERVICEPERSON perform the work.
Jacuzzi Home | Answered on Jun 29, 2019
Jacuzzi Signa 6 Whirlpool  JAC-B540... Logo
Popular Tags
22 questions posted
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
View Most Popular
Jacuzzi Home
  • Jacuzzi Home
Most Popular Question
jacuzzi hot tub model j 300 series fl 1
  • Home
