20 Most Recent LG WM-0532HW Front Load Washer Questions & Answers
You can turn the power on, and hit the spin speed button, and then start it. It should drain out.
If your still getting an LE error, and already have replaced the Hall sensor, it's most likely the Stator. If you know your date of purchase, this is most likely still under the 7 or 10 year warranty. Meaning LG pays for the part (over $100.00+),
LG WM-0532HW... • Answered on Feb 08, 2019
Most likely motor position sensor (also known as hall sensor). Under $20 part. Easy fix. Check out videos on repairclinic.com or appliancepartspros.com. http://www.ebay.com/itm/LG-Electronics-Washing-Machine-Rotor-Position-Sensor-Assembly-6501KW2002A-NEW-/252990897358?epid=710134311&hash=item3ae76ebcce:g:az0AAOSwnLdWsMSa
LG WM-0532HW... • Answered on Jun 23, 2017
u could try running a cycle or two with a mixture of 1 part vinagar to 3 parts water and see if it cleans out use hot water
LG WM-0532HW... • Answered on May 25, 2015
replace or it will jump all over the place
LG WM-0532HW... • Answered on Feb 23, 2015
The OE error is "Outlet Error" for the draining the water from the unit.
The unit is having trouble draining the water from the unit and that is why there is an error code.
You need to be sure there is nothing in the pump's filter (located at the bottom left on the front panel) that is restricting the water's flow.
If the pump's filter and housing is clear then it is the pump that has or is going bad.
The pump will fail because a seal will let water into the back side of the motor and case it to lock up.
If you need a part number for the drain pump, let me know.
LG WM-0532HW... • Answered on Nov 13, 2013
Your guess seems right as the damaged zipper could be stuck within the drum or movement and could cause friction to the movement. You can remove power and try to check on the free movement of the drum, if not the drum assembly must be removed and reset.
LG WM-0532HW... • Answered on Sep 27, 2013
The rear half of the outer wash drum (which contains the rear bearing and tub shaft seal) needs to be replaced. On a 1 - 10 scale, this rates a difficulty rating of about an 8. An experienced appliance tech can do it in about 2 hours, and hit you up for about $500. I do not suggest this as a do it yourself repair. Did you know that the new LG machines use a balance ring to make them much smoother running? (Hint: It may be wiser to replace the machine.)
LG WM-0532HW... • Answered on Aug 11, 2013
Open the small door at the bottom of the machine, left. pull plug from hose, it will drain about a cup of water. Then unscrew the filter and clean debris.
LG WM-0532HW... • Answered on Jan 23, 2013
Washing Machines Logo
82 questions posted
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
washer not complete cyclo show
  • Washing Machines
