20 Most Recent
American Standard Contemporary Kitchen Sink Liquid Soap Dispenser - 4305.20... Questions & Answers
Clogged bathroom sink
Try removing the **** Trap under the sink, there are two nuts one on each side. put a pan under the sink to catch the waste water in the trap first. ext loosen the nuts with a pair of channel locks or a pipe wrench turn the nuts counter clock wise direction till the nuts are loose slide the trap down and empty the contents of the trap into the bucket. Use rubber gloves so you don't get sick from germs. If the **** trap is plugged use a coat hanger to push threw the trap to get whatever is plugging it out. Rinse in a different sink, If it has the rubber gaskets I would recommend replacing the gaskets. Install in reverse. Do not over tighten the nuts or you will have to replace the parts. the trap looks like 2 opposing J .
10/16/2014 11:24:40 PM •
American...
Answered
on Oct 16, 2014
Forgot pasword
mcdevito75 here, you should be able to contact American Standard at 800- 442-1902 8A--6P EST. for your password.
7/13/2010 11:59:47 PM •
American...
Answered
on Jul 13, 2010
I have 2 American Standard deck mounted soap
All soap dispensers work on a siphon principal. There are o-rings inside these pumps and, over time, they dry out (even when surrounded by soap (which has an acid base)). Unless there is a way to dis-assemble these pumps and replace the o-rings, you may want to start looking for replacements.
5/16/2010 5:16:19 AM •
American...
Answered
on May 16, 2010
How do you put the liquid soap dispenser back
The "bottle" screws in from the bottom. The "pump" is inserted in the top. I usually fill mine from the top without taking out the bottle. Too much of a pain. Just make sure the large nut holding the hardware in place is secure before you start assembling the bottom and top. If it's loose, the whole thing will wiggle around. Good luck!
5/9/2010 11:22:57 PM •
American...
Answered
on May 09, 2010
The bottle that contains the soap for my sink
Hello. You will find that the bottle will come out once you remove the nut under the surface of the sink.
You have to get into the cabinet to do this. And, a faucet wrench, available at any hardware store will assist you greatly. Regards, joe
12/5/2009 1:31:27 AM •
American...
Answered
on Dec 05, 2009
Soap leaks from dispenser after use
sounds like a bad valve in handle, might be cheaper to just replace hadle buy the same one and just put in top that way you don;t have to climb under sink and loosen bottle
7/26/2009 2:50:40 AM •
American...
Answered
on Jul 26, 2009
Air switch randomly comes on by itself and I have to leave the breaker off
This could be caused by a faulty relay or switch in the control panel. It is best to have a qualified technician inspect the control panel and replace any faulty components. If the issue persists after replacing the faulty components, then it could be a wiring issue and a qualified electrician should be consulted.
2/22/2023 9:40:24 PM •
American...
Answered
on Feb 22, 2023
My American standard champion 4 sings after I flush it, while it I still filling. Then stops when filled.
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
7/12/2019 12:28:16 PM •
American...
Answered
on Jul 12, 2019
