20 Most Recent Pride Mobility Products Jazzy 1170 XL Plus Questions & Answers
Just wrap your wrist with an Ace bandage. LOL
Pride Mobility... | Answered on Sep 28, 2017
Hi Rob....I had the same problem with my 1170. Your problem is probably worn motor brushes. Replacing the brushes will most likely fix your problem.
Pride Mobility... | Answered on May 28, 2014
Locking/Unlocking the VSI
The VSI has a feature that enables you to
lock your powericon1.png chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speedicon1.png/profile indicator should ripple up and down.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked.
Pride Mobility... | Answered on Mar 24, 2014
Have you tried releasing the brake level? Should be located on the lower right side. I hope this helps.
Pride Mobility... | Answered on Feb 22, 2014
that fuse is located on a battery post cable,they are very exspensive for just a fuse but u will need to go to a hardware store and hope they have them or napa,oreily any auto motive parts store ok,those are special fuses
Pride Mobility... | Answered on Jan 20, 2014
shouldnt even move with charger plugged in sounds like a controller problem or joystick have a tech fro dealer check the error log they can tell u what is wrong from that
if i remember correctly there should be a single nut holding that tire on,use a rubber hammer and hit drive shaft and pull on tire at same time with other hand,it should move out far enough to get a large wrench behind the tire and push toward chair untill tire comes off
Pride Mobility... | Answered on Jan 19, 2014
Batteries are shot. Charger will not turn on when batteries are bad. Replace batteries.
Pride Mobility... | Answered on Nov 14, 2013
Should use proper 24 volt 2-4 amp off-board charger. A 3 red, 3 green flash code on a VSI/Remote Plus controller indicates high battery voltage.
Pride Mobility... | Answered on Jun 15, 2013
Code 9: brake fault. Check motor connections and make sure that the levers are in the engaged position - if you can roll the chair the gearbox is not engaged.
Pride Mobility... | Answered on Jun 06, 2013
Code 7: joystick problem. Be sure joystick is in center position when you power up. If rubber boot is worn out, replace it or repair it so that stick is in center position. Always check connections.
Pride Mobility... | Answered on Jun 05, 2013
Pride Mobility Products Jazzy 1170 XL Plus Logo
52 questions posted
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Mobility Products Health & Beauty
Most Popular Question
unlock controller
  • Health & Beauty
