20 Most Recent Kohler K-3360-G Revival One-Piece Toilet With 12" Rough-In, Seat, Cover, Br Questions & Answers
open were the water system is flush once watch the water rise localize the floaty tat rises with the water once u localize the floaty their will be adjuster were the floaty is then just lower the floaty adjuster down 2 half inches down once ur dun flush then the problem shud be solved.
Kohler K-3360-G... | Answered on Aug 18, 2010
after flushing observe flapper if it flops back and water is still getting by when tank is full than replace the flapper /if water is running down tube [high level]in tank than adjust level or if not responding to adjustment than flush unit is bad
Kohler K-3360-G... | Answered on May 31, 2010
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
Kohler K-3360-G... | Answered on Jan 30, 2009
Nope, but your seat doesn't really need protecting. All those paper covers do is mentally separate your backside from the countless bums that have occupied the same space.
Kohler K-3360-G... | Answered on Aug 27, 2008
We had a problem with phantom flushing. Call Kholer. They will send redesigned battery holder and top of flush unit for free. Seems to have fixed the issue.
Kohler Home | Answered on Jan 09, 2020
The only batteries are in the docking station. If the remote is attached to the docking station, take that off and set it aside. Next, carefully lift the docking station up and out from the mounting bracket. Look at the back of the docking station, push the two tabs outwards (away from each other) simultaneously to open the battery compartment cover. Replace the batteries (4 AAs) in the correct orientation. Reinstall the cover. Then replace the docking station on the mounting bracket and put the remote back on the dock if desired.
These directions are shown in the Homeowner's Guide (without the service parts) available on the product page: https://www.us.kohler.com/us/veil-intelligent-comfort-height-skirted-one-piece-elongated-dual-flush-toilet/productDetail/toilets/1120267.htm . Scroll down to the Installation section to find the link to the document. The current link to this guide is https://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1226974_5.pdf .
I hope this helps.
Kohler Home | Answered on Jan 05, 2020
First, identify the style of your quick connect hose.
See the steps on this Kohler Fawcet Link for disconnecting your pull-out kitchen faucet quick connect hose. Follow this link: https://support.kohler.com/hc/en-us/articles/360001798834-Disconnect-Quick-Connect-Pull-Out-Kitchen-Faucet-Hoses
Make sure the water valves are closed and the water pressure is relieved before attempting to service your kitchen taps.
Kohler Home | Answered on Oct 12, 2019
The brand of toilet doesn't matter. You need a product that cuts calcium and lime. It may take some soaking and scrubbing. Once you get it clean, use the product regularly.
CLR makes a line of products:
https://clrbrands.com/en-US/Products/CLR-Household/CLR-Calcium-Lime-Rust-Remover
Kohler Home | Answered on May 10, 2019
I don't know this specific tub, but here's the pictoral. The button (90105) should come out of its base, held by friction of O ring. This should allow you to disconnect the pressure line. If you are looking to replace the complete assembly, likely you will need a basin wrench to reach nut (65157).
kohler1-ggmuzyqdnvlyrlfigj0gxfoh-4-0.png Here are links to Kohler, specific to this tub.
https://www.us.kohler.com/us/catalog/svg_viewer.jsp?productId=415928&diagram=3 https://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1010564_5.pdf
Kohler Home | Answered on Mar 18, 2019
Kohler K-3360-G Revival One-Piece Toilet With 12" Rough-In, Seat, Cover, Br Logo
10 questions posted
Top Kohler Home Experts
john h
Bill Johnson
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
View Most Popular
Kohler Home
  • Kohler Home
Most Popular Question
toilet tank fill valve sprays water
  • Home
