20 Most Recent Kohler Santa Rosa K-3323-0 White Compact Elongated Toilet with Toilet Seat Questions & Answers
I would say yes....here is the .pdf for your toilet and it has nothing like that in it...your toilet should be a simple fill device and flush mechanisim...
I would return it for a new one...
http://www.us.kohler.com/onlinecatalog/pdf/1066506_2.pdf
heatman101
Kohler Santa... | Answered on Aug 05, 2010
look under the tank, their should be a nut holding on the old one. by removing that nut the part should free itself.
Kohler Santa... | Answered on Mar 28, 2010
it is probably falty get a new one
Kohler Santa... | Answered on Oct 30, 2009
Hacked off the old seat? You mean the closet flange that connects to the sewer pipe?
That's the part that has the bolts. They go up through the toilet base.
If you have just a straight sewer pipe now, you can connect a new closet flange to it.
1.Hardware stores sell a rubber sleeve. This sleeve fits over the cast iron, or copper, or plastic PVC pipe, and the new closet flange has a stem that fits down in the sleeve. There are two large hose clamps, that come with this rubber sleeve.
The rubber sleeve is an adapter. It adapts the 4 inch sewer pipe, down to the 3 inch stem on the closet flange. (Toilets are known as a 'Water Closet', hence the flange that the toilet bolts to, is a 'Closet Flange')
Whatever size of rubber sleeve you need to adapt two pipes together, they have it.
The new closet flange is made of PVC plastic.
(Poly Vinyl Chloride)
The flange itself is about 1/2 inch thick, and has provisions for bolts. (Use Toilet Bolts, and nuts)
Be sure the closet flange sits flush to the floor. The 1/2 inch thick rim of the flange, sits on top of the floor. The flange is then screwed to the floor with countersink head screws. The slots allow the bolts to just slip in.
IF, the flange Does Not sit level on the floor, and the area for the toilet base is not level, you need to make a flat, level surface!
Do Not half step this, or you'll have a toilet leak from now until the time you fix the floor!
Would appreciate it if you would rate my solution. If you have additional questions, state them by clicking on Additional Comments.
Kohler Santa... | Answered on Jul 17, 2009
your chain on your flapper is to long,adjust to proper hight.
Kohler Santa... | Answered on Jul 15, 2009
shut the water off to the toilet .Remove the toilet supply from the tank end.slowly turn the valve on to see if their is any water coming thru the supply.If water is coming thru the supply than you know you need to change the ballcock.This is the part in the tank where the water comes out of.
Kohler Santa... | Answered on Feb 02, 2009
okay depending on the type of toilet ball **** (i know its a funny word, but it's really what its called.) you have one the most standard type is the long wire with the big ball on the end. you need to adjust this ball **** so it goes lower test it out, flush your toilett and wait till the water drains then when its supposed to come back up push down on the ball **** and youll see the water will start to fill, so then adjust the little screw on the fill valve (the other side of the floater where its attached)
you may need to shut off your water supply and drain your tank depending on how skilled you are,
pretty simple work, if you have questions feel free to ask.
Kohler Santa... | Answered on Jan 16, 2009
It's not terribly complicated, assuming that by "install a new toilet" you mean where there was alredy an existing toilet. First, remove the old toilet. Shut off the water supply valve, and flush the toilet. Then use a spone to get rid of the water that remains in the tank. Remove the nuts on the two bolts at the base of the toilet where the toilet meets the floor. These are usually hidden under two plastic caps. Now gently rock the toilet until it comes away from the floor. Get help to carry it out. Clean up the old wax that's around the flange where the pipe disappears into the floor. Don't be a wuss, it's only wax. Now you'll need the new toilet, a new supply line, new mounting bolts (don't reuse the old ones) and a two wax rings. Yes, I said two wax rings. You'll see why in a minute. Assemble the new toilet according to the instructions provided. Now here's a warning: Do NOT overtighten the bolts the hod the tank to the bowl. You're dealing with ceramics here, don't break them. Now, put the new hold-down bolts in place on the flange. Read the insturctions that came with the toilet, but you have to do this NOW. Now you'll need a helper. With the toilet upsided down, unwrap a wax ring. Make sure it's room temprature or it won't seal. Press the wax ring around the outlet flange on the base of the toilet. Now you and your helper carefully turn the toilet over without crushing the wax ring. Lift the toilet and slowly lowe it so the wax ring is centered over the "flange" which is where the sewer pipe goes into the foor. Then press the toilet firmly in place. Now if you're like most people, you screwed up here and crushed the wax ring without being centered on the flange. That's why I told you to buy two. Now you know what not to do, scrape off the first one and start again. When you've got the toilet sealed on the flange, connect and tighten the nuts on the bolts. Now you may have to use a hacksaw to cut off the remaining ends of the bolts so you can get the neat little plastic caps to fit. Now connect the water supply line. Now's where you start praying. Turn on the water and let the tank fill. Check the supply line for leaks. Fix as necessary. Now flush. Is water running out from around the base of the toilet? No? Good, you got a good seal. Yes? Very bad. Time to go back to the home center for yet another wax ring. Repeat the sealing process and get a good seal this time.
Kohler Santa... | Answered on Jan 02, 2009
"Fluidmaster" makes a device that clips onto the tank and dispenses a solution into the bowl at each fill after a flush.
It goes inline with the tube runing from the fill valve, and dumps into the flush valve which goes into the bowl when filling.
Most LOWES carries them.
These are better than the ones that release the chemical into the tank because the chemical never has a chance of causing corrosion and failure of the tank to bowl seals.
Kohler Santa... | Answered on Dec 04, 2008
We had a problem with phantom flushing. Call Kholer. They will send redesigned battery holder and top of flush unit for free. Seems to have fixed the issue.
Kohler Home | Answered on Jan 09, 2020
Kohler Santa Rosa K-3323-0 White Compact Elongated Toilet with Toilet Seat Logo
17 questions posted
Top Kohler Home Experts
john h
Bill Johnson
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
View Most Popular
Kohler Home
  • Kohler Home
Most Popular Question
toilet tank not filling
  • Home
