20 Most Recent Moen 3867 Four Function Hand Shower With Slide Bar Questions & Answers
  2. start unthreading centre of head. I used a paint scraper to leverage at first. The threads get loose soon to hand loosen.0588438c-31ce-4428-9378-28140fa37adb.jpg
  3. loosen the spray ring using a lever to get threads started. Hand loosen after that.It's got right hand thread so the outer ring will be turning counter clockwise.3e2cc1ab-35f5-4521-a05f-e1167596fb04.jpg
  4. Take flat rubber gasket out of centre of head and take screw out, then pry white nylon part out with tool. I used tweezer.a1f4f121-e0e1-450a-a9b8-8777342a3262.jpg
  5. Clean scraped parts in hot CLR solution or any vinegar will work as well. Reassemble with lubricant so it works like new. Most likely need for disassembly is clogging or a broken "o"-ring.6fff7106-1b7b-4330-a3c6-089ea42233cf.jpg
Moen 3867 Four... | Answered on Jun 02, 2013
yes move it 3 or 4 inches to either side o0f center at a heigth appropriate for your height about heart high.
Moen 3867 Four... | Answered on May 20, 2011
hand tighten it on the side
Moen 3867 Four... | Answered on Dec 06, 2010
Usually whenever you do any repairs on plumbing, you dislodge calcium from the inner surfaces of teh plumbing. Check to see if ther is a mesh filter in the inlet side of the head. and remove and clean it. otherwise you could remove it and use a vacuum yo try and remove any deposit that may be in it. If that is unsuccessful,
you can always return it, but always remember to open the fawcett and run it before installing the head.
This is an essential part of any plumbing job. Good luck
. If your local store refuse to replace it Moen will gladly do so with no problem.
They are good like that.
Moen 3867 Four... | Answered on Mar 04, 2010
you need to remove the bar from the wall than the slider goes on the bar and than you reinstall the bar again
Moen 3867 Four... | Answered on Feb 03, 2009
replace cartridge
Moen Home | Answered on Jul 14, 2020
https://www.google.com suggests the following link:
https://www.hunker.com/12267493/how-to-clean-a-moen-shower-head
Quoting from link above:
How to Clean a Moen Shower Head By BRENDAN O'BRIEN
Photos.com/Getty
images
Taking a shower could be hazardous to your health if you do not properly and regularly clean your shower head. According to a study at the University of Colorado at Bolder, your shower head may contain harmful bacteria. But not to worry, with some old-fashion vinegar, elbow grease and about 45 minutes, you can take a shower with peace of mind. Clean a Moen shower head while it is still attached, or remove it before cleaning.
  • Volume 0%Detached Shower Head
    Step 1
    Remove the Moen shower head. This may require pliers or vice grips. If you use tools, place a towel or rag over the shower head to protect it from scratches and dents.
    Step 2
    Remove the cover of the shower head, if there is one. The cover may twist or snap off. Do not force it if it seems stuck. This is not a requirement. You can clean the shower head with still attached.
    Step 3
    Warm the white vinegar on your stove. Do not boil the vinegar. Gauge how much vinegar you will need by the size of your Moen shower head. You need to fully submerge the shower head in the vinegar.
    Step 4
    Pour the warm white vinegar in a bowl or bucket. Place the shower head in the bowl and submerge it in the white vinegar. Let it soak for 15 to 20 minutes.
    Step 5
    Clear the holes in the shower head with a paperclip or thin wire. Clear all of the debris from the holes. Dunk and rinse the shower head back in the vinegar.
    Step 6
    Rinse the shower head and cover with hot water. Re-install the Moen shower head and cover. Test the shower to make sure you have re-installed it properly. Attached Shower Head
    Step 1
    Fill a plastic bag with warm white vinegar.
    Step 2
    Place the bag over the Moen shower head so it is complete submerged in the warm vinegar. Place a rubber band or piece of tape around the stem, securing the bag to the shower head.
    Step 3
    Remove after 15 to 20 minutes. Take an old toothbrush and scrub off the mineral deposits and debris. Rinse off the shower head thoroughly with hot water and a wet cloth. Brendan O'Brien
Moen Home | Answered on Jul 07, 2020
remove the head remove restrictor add a gasket reconnect
Moen Home | Answered on Oct 29, 2019
Sounds like your cartridge is not properly seated and also may not be aligned properly.
Remove it and apply a thin coating of plumbers grease to the cartridge and then work it back into it's position rotating back and forth to insure it is going down all the way.
Moen 3867 Four Function Hand Shower With Slide Bar  Logo
Popular Tags
14 questions posted
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
View Most Popular
Moen Home
  • Moen Home
Most Popular Question
shower head will not stay up
  • Home
