20 Most Recent
Astro Pneumatic ASTRO ECONOMY SHOP TOOLS Questions & Answers
Need a manual for astro power 130 mig welder
I have the power mig 130 I just ordered a replacement whip and gun assembly for it and when it arrived it has three wire's a small blue one and a brown one then the large main black but my original only has two is it compatible or completely wrong for my welder
I'm looking to replace the
Easy enough, Your gas nozzle is compatible with a tweco part number 21-50, this nozzle has the insulator included
You can locate at any local weld supply like MSC Industrial or Praxair.
Hope this helps
Thanks
Please rate FIXYA
Hi, I have a Astropower
Hi:
Your gas nozzle is compatible with a tweco part number 21-50, this nozzle has the insulator included. You can find it at any Praxair welding store. Price is around 12.00 bucks.
I HAVE A POWER MIG 110 DOES NOT FEED WIRE UNLESS
Hi:
If your drive rolls need an extra pressure on them, that means you are using an oversize rolls, you did not mention what kind of wire is it (solid or fluxcore) probably your drive rolls are 035.
If youa re using fluxcore wire (no gas needed) the you should buy a knurled type roll that will cure the problem. Your machine is capable to weld up to 3/16" thickness using flux core wire or 10 gauge using solid wire-gas.
If this was useful to you please vote, thanks.
Drive wheels slip and won't feed wire. tensioner
make sure your drive wheels and contact tip is the right ones for the size of wire you are using. if your tensioner is too tight it will crush your wire and it will not feed through your contact tip.
loosen off your tensioner and remove any wire that has gone through your drive wheels.
I have a Hobart 10000
It sounds like your soft arc or arc start exciter is going bad. This should kick up the engine immediately, when you strike an arc. If you keep the welder on a truck, this is a common problem. Although Hobart makes a fantastic machine, all welders kept exposed to the elements have this problem from time to time. Before replacing parts, I would clean ALL contact points and replace any that are burnt or pitted. Sometimes, it will save you a bundle.
Burned resistors
I have the same problem with the Mighty Mig...Did you find these resistor values?
