20 Most Recent Black & Decker Husky 750w Power Inverter Questions & Answers
You are right. This is not enough to operate this freezer. You are going to need a bigger invertor it get it to work properly 900 or 1000 watt should be efficient even though it is not the best way to run the unit. If the unit has a problem you would be replacing the inverter all the time. Just FYI
Black & Decker... | Answered on Dec 21, 2013
750 watts is pretty close to one HP. However, the pump will have a much higher current draw on start up which may be too high for the inverter. (The accurate number is 745.699872 Watts per Horsepower)
Discounting any losses, 750 watts from a 120 volt supply will draw 6.25 Amps. so 1/2 horsepower should draw 3.125 while running. Startup current may be much more. Check your pump for its current draw (should be printed on the pump) and check it against the inverter's limits. It may be that the inverter is too light for the pump.
Black & Decker... | Answered on May 07, 2012
What is most likely occurring is that the unit is overheating and then is being shut down by the protection circuitry, this is a common thing on a device such as this at the age it is. That also fits with the exact symptoms you describe.
The ONLY remedy is to get the unit serviced, however it may cost more to repair, than it is worth to replace? What you need to do is obtain a "Quote" first and go from there.
Contact a Black & Decker local or head office, and ask for a referral to a Husky, authorized service center, now when here FIRST ask for that "Quote" only, and once you have been appraised, make your mind up as to repair or replace?
Black & Decker... | Answered on Jun 18, 2011
Looking at this, how many amps does the pump normally draw? Take this and multiply by 3 for start up current draw. Now, multiply that by 120 (volts) and this will give you the watts. Start up current is what will knock your inverter down. It won't kill the inverter but it will overload it on startup and turn off the unit. Since I do not know the size of your pump, this is my caution. You could always try it, the most that should happen is that the inverter will shut down.
Black & Decker... | Answered on Feb 06, 2011
What is the normal low voltage cutoff?It converts AC to DC correct?Just comment and I will get an auto email that you did so and will reply ASAP.Greg
Black & Decker... | Answered on Aug 12, 2010
Look for 3 - 40 amp fuses side by side near the fans, inside the unit
Black & Decker... | Answered on Oct 19, 2009
Yes, I took this unit apart there are 3 40 amp fuses in the unit. (Similar to blade type car fuses). You have to completely unscrew everything plus take off the top lable and plate to access the other hidden screws
its still ok
Black & Decker... | Answered on Jun 19, 2009
First...you need to find the amperage on the pump...your inverter is rated for 6.25 Amps...(750/120)...you will need an inverter bigger then the pump..I would suggest at least 1.5 times the size of the pump..bear in mind,..the inverter wasnt designed to start motors...so oversizing is needed..
Hope this helps
Black & Decker... | Answered on May 07, 2009
This type of inverter has large alligator clips on it because the amperage that comes through a cigarette lighter is insufficient and can result in blown fuses and overheating of the socket. Hook this one up directly to the battery without splicing a longer wire to it.
Black & Decker... | Answered on Apr 22, 2009
I can't answer your question but I strongly suggest you urgently contact the manufacturer or dealer in order to clarify this most important point as a 3kw inverter isn't cheap and shouldn't need replacing very often.
Black & Decker... | Answered on Aug 31, 2017
Sure, you can find it on amazon... here: Amazon com Husky jump start adapter . I hope I have helped. Cheers
Black & Decker... | Answered on Dec 01, 2014
Black & Decker Husky 750w Power Inverter Logo
Popular Tags
23 questions posted
Top Black & Decker Electronics - Others Experts
Sheldon Dedek
Vernon Taylor
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Electronics - Others
Most Popular Question
39 s problem many amps 1 2 horse sump
  • Electronics - Others
